cosworth parts escort sierra 2wd 4wd
Oke here goes
do to a garage clean up I have allot of small cosworth parts i want to sell
I am from Holland but shipping all over the globe is no problem
Al prices are without shipment and in pounds I accept Payment only by paypal
If you have any question you can always ask and apologies for my bad englisch
set of two silicone hoses turbo to air is 75mmx75mm turbo to intercooler is 85mmx80mm
i think it was for a t38 but might fit the t35 in mint condition 60,--
cosworth Alle types siliconehoses ask wich you need can give the cheap
ford sierra cosworth 2wd standard oil cooler 20,--
Escort en Sierra rs cosworth 4x4 crankpoely multibelt (small damages on belt part) all lugs intact 40,--
Escort en Sierra rs cosworth 4x4 powersteering pump 25,--
Sierra rs cosworth sedan en vleugel rear antenne 20,--
ford sierra cosworth 2wd turbo damper standard dismantled but its al there 20,--
only center parts of the pic
escort cosworth original new side wing vent clips i know there rare because i had he last set of mainland europe )25,--
4wd thermostat housing 15,--
original dump valve cosworth very good condition 15,--
cosworth 4wd front drive shaft only the other part 20,--
Sierra rs cosworth 4x4 standard darkbleu injectors 25,-- not mint bud good working order SOLD
Sierra rs cosworth 4x4 battary part loom 15,--
Sierra rs cosworth 4x4 lambda sensor 25,--
Sierra rs cosworth 4wd and 2wd abs ecu 25,--
2x Sierra rs cosworth 4-door rearwindow motors in the pic there are 4 with wiring but I only have 2 motors left I want 15,-- a piece so 30 for the 2
Some others please ask if you see anything
as said shipping is no problem
The cost for that would be
0-2kg 8 pounds without tracking and 12 pounds with tracking
2-5kg 18 pounds with tracking
5-10kg 24 pounds with tracking
These shipping cost are only for mainland uk so if you are from another country pm me for shipping cost I would be clad to ship allover the world
Also if there would be bigger than 100 x 50 x 50 cm and heavier then above pm me
thanks for watching
thanks for watching
155lee
Aug 14, 2015 11:21 AM
Aug 14, 2015 07:29 AM
