Mk4 Supra starting problem.....
Old Jan 11, 2012 | 01:43 PM
cfoster's Avatar
cfoster
Default Mk4 Supra starting problem.....
A mate had a 3.0 n/a Supra on a 1994 (mk4) and has a problem with it starting, it doesnt seem to be firing, just turning over and thats it!! Distributor and rota arm have been changed, ignition coil has been changed, all fuses etc are ok. Doesnt seem to be sparking or even attempting to spark!
Any ideas?!! He hasnt changed the leads but all 6 dont seem to be working so doubt its that!!
Chris
Old Jan 11, 2012 | 02:51 PM
Kam B's Avatar
Kam B
Checked the ECU?
Old Jan 11, 2012 | 03:12 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
possibly the cps or a wire going to that could be to blame, spent ages on a vr6 checking fuel, spark etc, cps wire was damaged.
worth a look, are the injectors "ticking" when cranking? should be able to feel them.
Old Jan 11, 2012 | 03:38 PM
cfoster's Avatar
cfoster
Kam, apparantly the ECu was checked and appeared to be ok (not sure who by).
xr2wishy - injectors are ticking and fuel is coming out of them, he's going to check the CPS sensor, whereabouts would he be looking for it (i've never worked on a toyota engine before!)
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
kevin36
Sep 2, 2015 06:24 PM
