206 perm 12v
Iv lost my permanent 12v feed on my 206 19d. So stereo loses memory an I just can't see how? Still got switch feed an checked all fuses I can see. Anyone had same issue?
Easiest way it to get the radio out and check the pins mate. When I was wiring a stereo in a 200SX it worked but kept cutting out because one of the earth cables had dislodged itself from its connector pin in the loom and I didn't spot it. Can't be difficult to trace.
After a nightmare with ignition switch I fuked that up by having it switched when put bk together so when switched on shorted all out. Now had to get new switch n barrel. An still no perm live. I heard there's a bsi unit know for braking??
Best thing you can do is get hold of the wiring diagram, when you find the fuse (Likely to be 10A or less, typically it protects other circuits as well) check you have a feed at the fuse terminal and it or the fuse itself isn't corroded.
Martin
Just a process of elimination have you just tried replacing the fuse? I don't know whether you have just done a visual inspection or tested it, I assume you do know the actual fuse?
As it may have some corrosion etc on the prongs so it's not making connection, despite looking ok otherwise.
Martin
Martin
Iv changed the fuse an tested the prongs I think I'm going to have to open the fuse box up. Mate I brought from said all was fine till 5p went in cigarete lighter an blow a fuse Wich he changed??
