uneven afr
Old Jan 9, 2012 | 05:05 AM
captiva's Avatar
captiva
Default uneven afr
I have stage 3 4wd and the afr is not consistant. I can set it at idle then drive it for a while and the afr reads much richer so I weaken it off and drive it again and it reads too weak.whats going on could it be the cold weather like -10C then changing to +2C being that there is more oxygen in colder air
Old Jan 9, 2012 | 05:36 AM
Rollinz's Avatar
Rollinz
webber ECU? or aftermarket managment?
Old Jan 9, 2012 | 02:11 PM
captiva's Avatar
captiva
Its regular weber L8
Old Jan 18, 2012 | 11:37 AM
wolf cosworth's Avatar
wolf cosworth
If in doubt ! Flat out !
Hi ,
I had an L8 was always on the high side ( better for the turbo then to lean ) .
Was your basic rpm the same when checked ?
Colour from your spark plugs are also important there I think a lot of these aftermarket gauges are not good calibrated there my spark plugs were showing slightly brown what should be OK.
Afterwards I installed close loop from MSD and the needle was dancing all the time trying to adjust
Steven
Chas
Oct 5, 2015 07:13 PM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
Marino
Sep 12, 2015 11:10 AM
Red_bull
Aug 25, 2015 06:27 PM
Stu @ M Developments
Trader Parts for Sale.
127
Oct 2, 2005 07:05 PM
