sold
Old Jan 8, 2012 | 10:47 AM
StephanCosworth's Avatar
StephanCosworth
Default sold
sold....
Old Jan 13, 2012 | 07:47 PM
StephanCosworth
Edit: All parts in 1st post now.
Old Jan 13, 2012 | 09:32 PM
neo's Avatar
neo
could you do me a favour and measure from the work top to the highest point on the throttle body i need some more clearance on my build but using a two peice 2wd one and want to know if this is narrower from its mating face on other half of inlet to the outer side of the throttle body edge if that makes sense...
Old Jan 13, 2012 | 09:35 PM
StephanCosworth
will measure it for you but if you can do a simple paint drawing or something what you want me to measure please, it's not really clear to me..
Old Jan 21, 2012 | 09:24 AM
StephanCosworth
update. Parts which are sold removed from the topic...
Old Jan 21, 2012 | 12:51 PM
j888cag's Avatar
j888cag
Drive like you stole it
Default hi
£1500
Original Sierra Cosworth 4wd ½ timingbelt cover.
£10
Original airbox Sierra Cosworth sedan.
£40
are these still for sale if so yes pleaseeeeeeeeeeeeeeeeeeeeeeeee
cas
Old Jan 21, 2012 | 03:11 PM
NZWINRZ's Avatar
NZWINRZ
What compression ratio is the engine?
Old Jan 21, 2012 | 03:25 PM
StephanCosworth
Originally Posted by j888cag
£1500
£10
£40
cas
Yes still for sale mate.
StephanCosworth
7.6:1 is the compression ratio
Old Jan 21, 2012 | 04:20 PM
olliehampton's Avatar
olliehampton
Is it standard grind crank bud
Old Jan 21, 2012 | 04:59 PM
StephanCosworth
No mate it's a crank with a grinded offset to get the 2100cc
Old Jan 21, 2012 | 05:57 PM
Hoogi's Avatar
Hoogi
Is the 200 Block Standard ????
Old Jan 21, 2012 | 07:47 PM
StephanCosworth
nope it's a 2100cc on 92mm bore to get the 2100cc out of it...
Old Jan 21, 2012 | 11:08 PM
neo's Avatar
neo
Hi sorry for the slw reply if you could measure the size ive highlighted please cheers Rob
Old Jan 22, 2012 | 10:18 AM
StephanCosworth
125mm is the distance mate.. Let me know
Old Mar 11, 2012 | 09:57 PM
StephanCosworth
added some parts and deleted some that are sold..
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
fordrallycar
Sep 30, 2015 07:57 PM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
