Tap Tap Tappy noise
So did mine I thought mine might have been a stuck tappet, plus a few others have had horror stories about bits of cam that break off and either screw the turbo or mash the engine, either way I would check the cams anyway peace of mind, if its a stuck tappet you might be able to try some of that wynnes hydraulic lifter tappet additive people have said that it works and frees sticky tappets up, can't think what it's called but I'm sure someone will come along and tell you, it's deffo made by wynnes
Not really matey it's luck of the draw could last another mile, could last another 100,000 miles, who knows, like I said try that wynnes Hydraulc valve lifter stuff if it's just sticky tappets it should quietern Down,
There a link here to halfords for it
http://answers.halfords.com/answers/.../questions.htm
Ah if it's a recent rebuild it is actually normal to get tapping, it should go away after a few more miles. Just keep an eye on your oil as you said you had a leak.
Ang use the wynnes stuff should be sound then
Im scared of that additive. Is it widely used like? Dont wanna be adding stuff to the oil but If its ok i will use it.
Yeah, its been sitting around for about 3 weeks aswell.
It's fine to use matey a lot of people have used it on here and had good results, it won't damage your engine
Just take it on a long run if it's been
Sitting and add some wynnes stuff sounds like all the oil has drained from the head into the sump being stood so tappets maybe sticking a bit
I've had it twice last year. 1st time I tried the Wynn´s stuff, Didn´t help. Then I tried the ATF trick. Poored a 1/4 of a liter of ATF in my engine. I then let it idle for a couple of hours so it was hot. I then revved it like a madman and hey presto the noise was gone. Changed the oil twice.
The second time I just gave it the beans, so thrasted it really. Pulled it to 6500 RPM, I never do this, but it did help. The vibrations at higher revs help to unclog the dirt.
As said it's most likely to be the lifters, when was the oil last changed, as if this is neglected this can affect them!
But otherwise if it's been standing for a while it is normal for them to take a while to quieten down.
Worst case scenario one or more of them is blocked, sometimes a 'spirited blast' can help as the oil gets hotter and thus thinner which can help!
Or as said try the Wynns product.
Martin
Martin
