Is siemens 55lb ok to use with t38?
As above^ I have 55lb siemens to run with t38 which I thought would be ok but have been told by a friend they are not big enough to fuel for a t38?
83's on a T38 - James mine was maxed on 55 on a Harvey T38 as was mentioned to me by Stu when it was setup, if it had something to do with head I have on mine I'm not sure as that was also asked
They are defiantly better on 83s if you want to max the turbocharger
But we do quite a few t38 55s files and they work ok at sensible / bar peak boost levels on the small ones
It's only the boost junkies who run into problems lol
James last 4x4 stu live mapped for me,the 55,s were maxed out on a t34,so you would need to run reduced boost ,which to me is a waste of time as i want a turbo working flat out
cheeRS stu
cheeRS stu
I've never seen a 55s map near 255 on a T34. I've never seen a T34 do 450bhp either.
Yes, at high rpm we were having to bring yours down a little as fuel delivery is obviously at its highest at high rpm and they were right on the limit up there.
But for a general set up, with a stdish spec engine they work fine.
Get on it Kev thats the same box i had in the blue escort
I would worry more about a standard box shitting itself way more than diffs.
Not with a 40 psi spike they ain't pmsl
When you come for mapping can you bring some bags and boxes along with you, so I have something to sweep your gearbox into off the road pmsl
So was the GT30 but you are going to end up with 450 + bhp and over 400ft of torque. You may get away with it just going from my history of 5 boxes and 0 diffs all with less power than your looking to have.
If you dont want the noise of a straight cut then your sort of limited to a Fixit box or a Dome Genesis box as there both semi straight cut, saying that I think Martoon is running a frozen and polished standard box in his 3 door.
Danielbetty
Oct 3, 2015 06:01 PM
timsrs
22
Sep 24, 2015 08:14 PM
andyescos
15
Jan 28, 2006 03:51 PM
