Cosworth Parts
I'll try and get some photos at the weekend i'll post everything bar the Block, Diff and Beam.
Crank span a shell on number 4 will need a grind has not been ground before.
£150
4 x Conrods
£125
4 x 4x4 Pistons with all rings some slight valve marks
£100
4 x 4x4 Pistons no rings has been chemically cleaned looks like new with very light valve marks
£150
3 Door rear beam with arms and hubs and rear ARB all poly bushed
£100
4x4 Rear ARB 18mm with both clamps recently powder coated gloss black hasn't been fitted since comes with 2 oem bushes in mint condition
£60
2WD engine mount arms recently powder coated gloss black haven't been fitted since
£35
Escort Cosworth Hockey Sticks glass fibre replicas brand new never fitted
£60
2WD LSD 3.64 Diff came as spare with my 3 Door has sat in my garage for 8 years no idea of condition missing both drive flanges
£100
Rich
£150
4 x Conrods
£125
£100
£150
£100
£60
£35
£60
£100
Rich
http://www.palletways.com/en/united-kingdom.html - just make sure you pack it and strap it well
Not really sure mate it's hard to say before I got a new block I was told it might be better put a liner in that way you can keep the standard bore size as the others are in good nick probably just need a hone.
Here's a photo of the damage from when I took it out the only difference is it's strippped bare now:
Rich
Rich
Rich
Rich
3dr cossie
11
Dec 21, 2015 03:38 PM
155lee
Aug 14, 2015 11:21 AM
Aug 14, 2015 07:29 AM
