General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Direct comparison from 55lbs to 403s, 403 - horrible idle until closed loop was fitted, 55lbs brilliant idle even without closed loop - both on MSD chips.
exactly better spray pattern and when your using a big injector an having to close the duration more at idle they handle it properly plus the injector responce is better under load so fuel is better managed
My guessing is its not mapped properly then.
I have 83lb siemens no closed loop and its perfect.
I think you have misread the above , because he is saying he never had closed loop with Bosch and it's idle was not great but using siemens still without closed loop and it was better
