Ctek battery conditioner hard wire?
Hi just got a ctek 3600 for the sapp and it comes with a hard wire lead that bolts on battery so you can connect conditioner without the need of crocodile clips, this lead is only 40 cm and I want to extend it and run it under wing to front of car so the plug is just under bumper or number plate to save the need of opening bonnet all the time, anyone done this?
This is the thing I bought - can't remember where I got mine from but the price was probably about the same.
http://www.amazon.co.uk/Ctek-CTE-562.../dp/B0016LA5O8
if it has popped a fuse would it stop battery getting charge?
I thought the CTEK indicator lights would show the circuit wasn't charging? Could be the battery is goosed and it's trying the recycle mode? Seem to recall that can take many hours to complete.
Failing that, and if the fuse looks ok, use the croc clips or eyelets that come with the CTEK for the battery connection for now.
That way you'll know the battery is being charged overnight, and tomorrow you can try the cig lighter - if it heats up, your socket must be ok. If it doesn't you have some investigating to do.
Thanks for reply mate, I charged it following instructions in box, it had power light on, I'll use croc clips to battery I do it that way then check fag lighter, thanks
