granada scorpio battery
Old Jan 3, 2012 | 01:02 PM
damien roe's Avatar
damien roe
Default granada scorpio battery
am i right in thinking the granada/scorpio was fitted with a larger battery than a sierra cosworth would anyone know what battery the granada had
thanks damien
Old Jan 3, 2012 | 01:17 PM
mick's Avatar
mick
i believe its an "097" thats what i took off and replaced with on mine ..
Old Jan 3, 2012 | 01:21 PM
dojj's Avatar
dojj
Resident Wrestling Legend
it had more amp hours or soemthing than the sierra one as the granada had much more electrics to fiddle with
you should be ok charging it up with your standard 90 amp alternator though, but you may have to upgrade if ytou are currently running a 70 amp one
Old Jan 3, 2012 | 05:34 PM
iansoutham's Avatar
iansoutham
OCD Victim
Biggest battery that will physically fit in a Sierra battery tray is an 095 (680A crank). I have one in mine and it is physically the same size as the side of the tray from front to back.
Old Jan 3, 2012 | 06:11 PM
silver's Avatar
silver
The 2.8 XR4i have 097 batterys fitted as standard.
Old Jan 3, 2012 | 08:34 PM
iansoutham's Avatar
iansoutham
OCD Victim
097 is a heavy duty Sierra and standard Transit Diesel battery. 095 is a larger capacity battery still, even though the number is lower.
085 batteries are normally around 44AH and approx 390A cold-crank.
097 batteries are normally around 63AH and approx 525A cold-crank.
095 batteries are normally around 75AH and approx 680A cold-crank.
085 is a standard battery used on Escorts, Fiestas and most Sierra models.
097 is used on Escort and Fiesta diesels, Sierra and Transit diesels.
095 is used on Scorpio diesel, optional heavy duty for Sierra 2.5TD.
Obviously there are more models that use each various battery, the list above is just examples.
Best to remember as well that there is no point using a 45/55A alternator to run a car with an 095 battery with lots of electrics running, the same as it is not worth having a 95A alternator to run an 085 battery.
Old Jan 3, 2012 | 10:51 PM
damien roe's Avatar
damien roe
thanks lad's a very helpfull thread
Nov 1, 2015 06:53 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
cliffy70
Sep 20, 2015 09:18 PM
Flatlinedan
Sep 18, 2015 12:41 PM
