Glovebox clips?
Old Jan 1, 2012 | 05:50 PM
K464TGV's Avatar
K464TGV
10 Year Member
Default Glovebox clips?
Hi All, I recently got hold of a couple of glove box clips to hold and pivot the glovebox of my Sapphire Cosworth as the originals had snapped and as such the box would fall out when opened. The replacements seem to have a hole where the originals had some sort of plastic plug/screw connected which fitted into holes already in the dash to hold the clips in place. Does anybody know if the ones I have bought are simply a bolt in job or is there a type of plastic plug/screw that I should be using? Thanks in advance
Old Jan 1, 2012 | 06:42 PM
cossie330's Avatar
cossie330
Sounds like youve got the pre facelift glove box clips which fix in with a screw
Old Jan 1, 2012 | 06:46 PM
K464TGV's Avatar
K464TGV
10 Year Member
Thanks very much for the response!
Old Jan 1, 2012 | 06:49 PM
cossie330's Avatar
cossie330
No problems, i would of thought they could be made to fit somehow.
I see youre fairly local to me
Old Jan 1, 2012 | 07:56 PM
K464TGV's Avatar
K464TGV
10 Year Member
I think I've got some bolts that shouldn't look out of place in the car but will be in touch if I'm struggling... On another note are there any meets which are held or organised locally as would be nice to get involved...thanks again
Old Jan 1, 2012 | 09:19 PM
neil andeRSon's Avatar
neil andeRSon
If you need the facelift ones let me know as I have a sierra hatch being broken.
Old Jan 2, 2012 | 08:10 AM
iansoutham's Avatar
iansoutham
OCD Victim
Facelift ones are available from Ford, finis 6629973, about £1 each last time I got some.
155lee
Sep 23, 2015 01:27 PM
Caddyshack
Sep 16, 2015 08:13 PM
