Group A coil wiring up ???
Hi guys im connecting up my 2wd loom into my car build and have the wires shown in picture below, but i am trying to wire the Group A coil up to them am i wires short here ???
anyone got a wiring diagram
Rob
Rob
The negative wire (green) is on the engine loom. The black wire (positive) is on the main body loom.
As it looks like you are putting the engine into a kit car (from that picture), you will probably have to run a new wire from the ignition circuit.
Hi guys ive split the loom wiring back and your indeed right the black wire is deffo not in the engine bay loom as steve says it might be so i need to run the black wire from the ignition then yeah ????
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
