Breaking Escort Cosworth Big Spec
Delete Aero lux Model With Full Raven Leather Interior
67k miles with all old mot's
Escort Cosworth 500BHP Engine
Engine Spec/Built By Amhed And Grove Garage, it had a refresh 4000-5000 miles ago
long studded 200 block
WRC triple layered head gasket
Ported head
Mahle pistons
RS500 Plenum , elbow & throttle body
8X injectors
Distributerless igntition
roose motorsport 76mm boost hoses
K & N cone filter
Bailey Motorsport twin piston re-circulating dump valve
Hydrid T4 with 360 thrust bearing .
RS500 Turbo hanger
Turbo jacket
Ceramic coated 2WD exhaust manifold & swan neck
stainless steel exhaust System
Modifield fuel system with 2 x 044 pumps and 2lt swirl pot feed by a 023 pump
(same as harvey uses) with braided teflon lines, areoquip fittings and a brand new fuel filter
alloy breather system
alloy header tank
alloy power steering tank
Management
WRC/Motorsport braided wiring loom
Pectel T2 ecu
Lightened Crank pulley (36-1)
Air Injector's
Transmission
Pete Doughty straight-cut gearbox
Steel main shaft bearing
Alcon 6 paddle clutch
Suspension
Koni adjustable dampers
Ahmed Bayjoo dual rate springs
powerflex polyurethane bushes
Ahmed bayjoo 6 degree rear beam
Front and Rear strut brace
Wheels
18" Rondells
Cat 1 alarm/imobiliser and tracker fitted
Wanting to sell the shell fully trimmed but i might split it right down.
Please check out my website for other Cosworth Part i have
www.mt-motorsport.com
Ported head
Mahle pistons
8X injectors
K & N cone filter
RS500 Turbo hanger
Turbo jacket
alloy header tank
Management
Pectel T2 ecu
Air Injector's
Transmission
Suspension
Wheels
18" Rondells
