Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Quickclear screen issue
Old Dec 19, 2011 | 12:44 PM
blader1611's Avatar
blader1611
Default Quickclear screen issue
I have a Focus MK2 (05 reg) and only the passenger side of my quickclear screen works. I have checked the fuses and they appear ok. The next thing I have been advised to check is the connection which is located underneath the scuttle panel. i have read somehwhere that if you remove the scuttle panel then you are more than likely to damage it (the way its built rather than ham fists) thus requiring a new one. Was that only on the MK1's or does MK2 have the same issue? Do you just remove the clips that are at the front of the panel or are there hidden ones somewhere? any other suggestions on this problem will be greatfully received.
Mark_
14
Jan 16, 2016 05:27 PM
SMILER258
Sep 28, 2015 09:04 AM
pabloXR
Sep 21, 2015 12:42 PM
37
Sep 20, 2015 02:24 PM
ST-170
Sep 4, 2015 11:02 AM
