Xr2i running prob
Right basically need 2 get the fkcing thing working as im supposed 2 be at mclaren this week again and couldnt get there today!!!
Long story shot basically it wont run properly, a lil while back it cut out and wouldnt run then fixed itself. the last week or so it was a bit jumpy when cold but fine when warm, but last night on my way up the m23 it played up and had 2 come home.
Basically now it has problems ticking over, then will run ok untill you try to drive it and coughs and splutters and dies. I changed the fuel filter as i was told if this was clogged could be starving fuel so done it and its still the same, what else could it be?! Seems to be sparking but just gonna go out and double check each plug has sparks. The plugs are all dry so its not getting flooded or anything. Oh and its a 1.6 8v!!!
Cheers for any help, fookin things been fine up until now sods law
Cheers for the help
Right when its left for a bit then cranked it wont turn over at all till its been cranked a few times then starts splutters and dies a and keeps doin it unless u rev it but again just splutters, could it be the fuel pump thats fucked and not getting enough fuel in?! obviously when its cranked a few times some will get thru and prob enuff to turn over but not run properly?!
bttt
Fueling seems ok as i disconnected the feed to the rail and plenty is getting thru
Had new plugs and leads just b4 xmas so cant see it being them either
So pointing to something electrical...........
Nah brad put in Ł15 worth of unleaded last nite sure of it!!!!!!!!!!!!!
Wheres the cut out switch on fez's then mate?!
Give me a cos and i know where i stand aint got a clue what 2 look 4 on a CVH!!!!!!!
Cheers mate, doubting its that but will have a look, as i say after a bit of cranking it'll run but coughs and spluters, but u can rev it then it'll sound ok then cough and splutter again!! might be one of the sensors
Eigdoog
Sep 13, 2015 05:46 AM
