2wd/grpa blue alloy brake bells to suit ap type discs - £90 delivered
Brand new set of alloy brake bells with a 12 bolt fixing and a pcd of 203.4mm i think it is to suit the most common 330mm discs and possibly 315mm and some others but please check this is correct for what you want as i will not refund if they don't fit etc
They are ford 4x108 pcd stud pattern and hub so will be good for any ford cosworth/escort sierra etc that use the correct suitable discs etc
Been freshly anodized blue and have only been trial fitted to car but have never had a disc bolted to them so maybe just a few scratches from the studs when fitting and removing them
Only selling as just bough a brake kit that uses smaller discs that don't fit these bells unfortunately
£90 delivered to uk but will ship elsewhere, pm me for a quote
Thanks
Marc
Thanks
Marc
mark i aready have the alooy to make my bells ( as im going 5x112 )
but dont suppose you could make a drawing up with the measurements could you fella ?
so ive something to give to my machinist ?
glwts
beef
glwts
beef
Graceland
Jul 31, 2015 10:34 AM
