Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
New to the site
Old Dec 13, 2011 | 07:12 AM
marcusst170's Avatar
marcusst170
Default New to the site
hi
just recently put a deposit down on a st170 in gun metal grey, cars on 52 plate having done 73k, no proof of cambelt change so should get that done first of, what should i look out for?
engine management light was on so asking them to sort that out before i take it, car was running nicely with not taps or odd sounds.
thanks !
Old Dec 13, 2011 | 07:53 AM
oldford's Avatar
oldford
Engine management light on when the car is allready on sale? NOT a good sign.
Suspect a defective catalyst. That will not show up as a fault code untill you have driven the car several hundred miles. Also suspect removal of the engine light, so check if it will lit when you switch on the ignition, after they have sorted it out.
Old Dec 13, 2011 | 09:58 AM
marcusst170
thanks for the reply, i was thinking that or a lamba sensor maybe, will be checking it out that it lights up when the key is turned to, car is in good condition but my deposit and sale of the car to me is subject to this being sorted plus they supply 3moths warranty
Old Dec 13, 2011 | 10:57 AM
oldford's Avatar
oldford
If a seller is to supply warranty, one would expect the problems to be repaired before someone looks over the car. That might sell the car a lot easier. You have to repair it anyway because of the warranty.
Only 3 months warranty seems short to me, but I don't live in the UK. Worth checking what the time-length of the average warranty is.
Take great care here. I would do a code read for all systems and an exhaust gas analysis - in my presence - before deciding if I would want to buy the car.
I have seen ABS lamps connected to the oil pressure switch and those kind of things.
Old Dec 13, 2011 | 11:27 AM
marcusst170
yea i totally understand id like to see proof that the test has been made etc
Marv888
Sep 26, 2015 03:44 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
