Cosworth 4x4 Bara straight cut gearbox £3000
its done less than 1000 easy miles (mainly motorway) since built.
Will come with build sheet which includes...
service rebuild transmision inc dyno test 150
mt75 big tooth gearset 2650
shot peen gearset 100
heavy duty 1st 240
heavy duty mainshaft 1000
mainshaft bearing 20
input bearing 20
molycoated syncro rings x5 100
uprated centre vc to 60nm 20
4300 on parts alone.
provided in casing full built up ready to fit, will come with gear cradle, alloy bushes and gearstick
fully straight cut so noisy
modded for hydraulic clutch
if it would help the sale i will take payment in 2 parts?
box still in car ATM, was aiming to remove over winter but if someone wanted it I could remove straight away.
£3000
heavy duty 1st 240
input bearing 20
£3000
Anutternutter
Aug 21, 2015 06:07 PM
charliecosworth
Aug 19, 2015 02:00 PM
Aug 14, 2015 07:29 AM
