2WD Hart Inlet with fitting kit-Now Sold
Old Dec 10, 2011 | 11:47 AM
pacificzetecturbo's Avatar
pacificzetecturbo
Default 2WD Hart Inlet with fitting kit-Now Sold
Hart Inlet to fit 2wd with fitting kit.
Bought New 2 weeks ago, but doesnt fit
Brand new only fitted onto engine, never run.
Is painted heat proof crackle black but i can blast it off if you didnt want it painted.
£450 + Postage
Pay pal by gift only please.
Thanks
Old Dec 10, 2011 | 01:36 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
That will sell quick
Steve
Old Dec 10, 2011 | 03:23 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
Where abouts in Kent are you m8
Steve
Old Dec 10, 2011 | 03:30 PM
pacificzetecturbo
Steve
Herne Bay, or work in Canterbury.
Old Dec 10, 2011 | 03:56 PM
Moonstone Steve.
Am i right in thinking they make different types depending on what throttle body you use.
Steve
Old Dec 10, 2011 | 04:07 PM
pacificzetecturbo
Default hart
Yes mate they do, this is for a std 2wd throttle body which i was told would be good for 500-600bhp.
Old Dec 10, 2011 | 04:14 PM
Moonstone Steve.
I do have a 2wd throttle but have just got a late escos one which i really wanted to use, do you know what the difference is?
Steve
Old Dec 10, 2011 | 04:41 PM
pacificzetecturbo
Not entirely sure mate, ask steve4i as I know he looked into the differences.
Old Dec 10, 2011 | 05:50 PM
focus 4x4's Avatar
focus 4x4
Steve
any cosworth TB will fit mate .
Old Dec 10, 2011 | 05:54 PM
AA JASON's Avatar
AA JASON
How much are these new, and whats the improvements in low down power if any?
Old Dec 10, 2011 | 06:01 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Not true.
The ST Escos TB has a port for the ISCV which when fitted to the plenum (if it's for a standard TB) the flange doesn't cover which would cause an air leak.
I've just had a little section welded into my throttle body to get around this problem!!
I'll stick some pics up when I get home!
Old Dec 10, 2011 | 06:38 PM
turbomook's Avatar
turbomook
so would this fit a 4x4 escort cosworth?
Old Dec 10, 2011 | 08:32 PM
Any pics of the rest of the car, Mk2 fiesta ?
Old Dec 10, 2011 | 08:41 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
This is what one looks like for a ST Escos TB
Steve
Old Dec 10, 2011 | 09:01 PM
mr noisy's Avatar
mr noisy
Yes i also wanna see more pics of this car
Looks like a mk1 fiesta if im correct ?
Old Dec 10, 2011 | 09:10 PM
pacificzetecturbo
Yea it's a mk1 fiesta, loads of work already done just a few bits needed to finish it.
Old Dec 10, 2011 | 09:43 PM
Very nice
Old Dec 10, 2011 | 10:33 PM
neo's Avatar
neo
would you be able to measure the distance from the inlet manifold joint to the hart plenum.... to the outer part of the throttle body housing please ive a serious cleaance issue on my install width ways thats all..
Old Dec 10, 2011 | 11:42 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
What's the difference between this & the 4x4 version? Would it fit a 4x4 saff?
Old Dec 11, 2011 | 06:30 PM
BRAMMER's Avatar
BRAMMER
2wd and 4x4 T/B will fit this the S/T is a different shape but the trumpet section from either the 2wd, 4x4 or S/T will fit but the S/T seems to be slightly longer and does foul ABS block on 3dr's at least.
I think all the above is right and from my experience but if not please correct me
Old Dec 11, 2011 | 06:41 PM
focus 4x4's Avatar
focus 4x4
Originally Posted by Kitchen Devil
Not true.
I stand corrected! ;o)
Old Dec 11, 2011 | 07:22 PM
Sonic Boom's Avatar
Sonic Boom
Correct
Rich
Old Dec 11, 2011 | 07:33 PM
turbomook's Avatar
turbomook
so will it fit a 4x4 escort cosworth with a standard t/b running a spec r cooler?
Thanks
Old Dec 12, 2011 | 03:57 PM
pacificzetecturbo
Just to clarify theres nothing wrong with the manifold below is a picture of it in my fiesta, cause the rad and intercooler are that much closer to the engine i cant get the hose on the throttle body.
Old Dec 12, 2011 | 04:21 PM
m500nte's Avatar
m500nte
Thumbs up
hi buddy u have pm
Old Dec 12, 2011 | 05:17 PM
BRAMMER's Avatar
BRAMMER
Thanks
You would need to speak to Spec R - he will tell yay or nay
Old Dec 12, 2011 | 06:55 PM
turbomook's Avatar
turbomook
Cheers mate, just wanted to double check, when Pete made my spec r cooler it was designed to go with a Hert plenum.
Old Dec 12, 2011 | 07:36 PM
pacificzetecturbo
Sold now thanks for the interest.
RUBY123
Oct 22, 2023 12:04 PM
carlo
24
Oct 5, 2015 08:20 PM
Aug 17, 2015 09:06 PM
Aug 12, 2015 10:03 PM
Bart
Aug 9, 2015 09:04 AM
