Sapphire wheels
A mate of mine has a 2wd Sapphire Cosworth on Gaz Coilovers. Currently he's on standard wheels but the spings are touching his tyres.
Is there somebody who knows a wheel that would fit the car better? He wants to stay on 15" if possible.
Thanks
Thanks
If they are just touching the spring on the fronts, put on 2 or 3mm spacer and job done.
I'm running 3mm spacers on my 17" road wheels as they are 8 wide et35 and just touch, no big deal. Spacers lower the offset et of your setup.
I have a Sapph on Gaz Golds and there is a few mm between tyre and spring - also on standard Sharktooth alloys. As said, a wheel spacer is the easiest option but maybe tyres with less bulge/stiffer sidewall/more pressure?
Charlie
Charlie
Tony W
Sep 9, 2015 12:08 PM
Adam Graham
Sep 6, 2015 06:04 AM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
