My MSD chips L8.
Old Dec 2, 2011 | 06:57 PM
James @ M Developments.'s Avatar
Default My MSD chips L8.
The first chip that was used on my old saff, made 370bhp, 420lb/ft at 34psi peak.
The ultimate chip for an ace road car. and was returning over 30mpg on cruise.
7.5:1 CR
Mild ported head
55lb Injectors
T34.48
Std Cams
Closed Loop
L8 Std Board
cost £350, so grab a bargain at £150.
Also, my 500bhp spec chip
7.2:1 CR
BD16 inlet BD14 Ex
Ported Head
83Lb Injectors
Air Injector
Closed loop
L8 Std Board
RS500 T4
Will make over 500bhp at 32 psi on a similar spec engine.
Cost £400, will sell for £200
Any questions just drop me a pm. All come with the correct instructions, we can obviously add ALS/LC etc at your cost if you so require.
Old Dec 2, 2011 | 11:55 PM
fezzajsy's Avatar
fezzajsy
hi mate can the any of the chips be altered to suit a diffrent spec?thanx
Old Dec 3, 2011 | 08:36 AM
KSA-Cossie's Avatar
KSA-Cossie
Yes they can mate
Old Dec 3, 2011 | 09:53 AM
we can depending on what it is really.
Old Dec 4, 2011 | 10:53 AM
RS SHAUN's Avatar
RS SHAUN
Could you change the 55's chip to standard head and standard comp James?
Cheers shaun
Old Dec 4, 2011 | 03:35 PM
saph cos rob's Avatar
saph cos rob
swindon rsoc
pmed
Old Dec 6, 2011 | 07:32 PM
Upski!
Old Dec 8, 2011 | 12:52 PM
cossie.087's Avatar
cossie.087
pmed
Old Dec 10, 2011 | 10:25 AM
Upski!
Old Dec 26, 2011 | 06:47 PM
fezzajsy's Avatar
fezzajsy
Originally Posted by James @ M Developments.
standard CR
BD14 inlet std Ex
Ported Head
8 green Injectors
Air Injector
L8 Std Board
wasted spark
RS500 T4
james could u pm a price to alter the chip to the above spec pliz
Old Dec 26, 2011 | 07:00 PM
MrC's Avatar
MrC
James??? Can this chip be modded??? Chip no:3733
Don't know the full spec other than I have it all except the t4 and the air to air injectors..
T34 and Amal.....
Or is this false economy
TIA
Old Jan 3, 2012 | 08:12 AM
if its an injector or turbo change we start with a new base file, so its new chip time.
when you buy a new one, We can give you a refund on the old one though if you have an invoice
Old Jan 3, 2012 | 09:42 AM
fezzajsy's Avatar
fezzajsy
ok mate.
Old Jan 3, 2012 | 03:40 PM
RS SHAUN's Avatar
RS SHAUN
Cheers shaun
Old Jan 3, 2012 | 04:11 PM
YHPM!
Old Jan 3, 2012 | 07:52 PM
RS SHAUN's Avatar
RS SHAUN
Replied
tankybaby66
Feb 6, 2016 02:24 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
tib2220
Sep 14, 2015 12:33 PM
RSmark84
Sep 13, 2015 01:29 PM
