Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Mk6 Fiesta 2.0 duratec turbo help
Old Nov 28, 2011 | 07:21 PM
Abyssus92's Avatar
Abyssus92
Have To Be Turbo'ed
Default Mk6 Fiesta 2.0 duratec turbo help
Hi to all
I have a 03 1.4 fiesta and im seriously considering a 2.0 duratec turbo conversion from a focus rs. I would also like to say that im a mechanic so i do know what im getting into i have done similar things before with other makes of cars. i would just like a bit of advice from people who have done this before, i know your on here somewere . any potential or major problems i may incur or just general bits of help or tips anyone can give me.
Thanks very much
Old Nov 30, 2011 | 07:21 PM
Fiesta_Jed's Avatar
Fiesta_Jed
Dont use a focus rs engine.
It is a nightmare if you want to use stock managment and even if you dont it is alot of work to fit an old zetec engine.
A fiesta st engine is a proper duratec. It will bolt right in and the stock st ecu can be remapped for a turbo.
The duratec from a fiesta st bolts right in and is a much much better engine.
Old Nov 30, 2011 | 07:44 PM
madfezzer's Avatar
madfezzer
easy swap ,management can be a problem tho , use aftermarket job done!
big_Rad
Sep 15, 2017 09:36 AM
Matt Baxter
Sep 16, 2015 08:30 PM
