anyone used this: edit thread size needed ???
Old Nov 25, 2011 | 07:18 PM
griffo69's Avatar
griffo69
Default anyone used this: edit thread size needed ???
http://www.machinemart.co.uk/shop/pr...&TC=SRC-needle scaler
any thoughts on this
Old Nov 25, 2011 | 07:28 PM
COLEYST200's Avatar
COLEYST200
you wont to use these mate
Old Nov 25, 2011 | 07:32 PM
griffo69's Avatar
griffo69
cheers mate, yea ive seen these on ebay for only about 5 pound.
what are they like to use, do they throw metal filings off like the non twisted brushes, dont fancy having to pick the bits out of my cheeks lol
Old Nov 25, 2011 | 07:38 PM
griffo69's Avatar
griffo69
vid of it used
http://www.youtube.com/watch?v=Xha4xY-dMrQ
Old Nov 25, 2011 | 08:11 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
needle scalers are alright if the undersealer is brittle, if it'd soft then it won't work too well.
twisted wire cup in the grinder will do a better job.
Old Nov 25, 2011 | 08:38 PM
griffo69's Avatar
griffo69
ok thanks mate, in never knew that. so i`ll need 2-3 cup brushes ??? and a lot of patience to do my underside
Old Nov 25, 2011 | 08:46 PM
dingla rs's Avatar
dingla rs
GRINDER YOU SAY IAN were is andy at
these are what you need for job sake the nibbler off
Old Nov 25, 2011 | 09:27 PM
stevieturbo's Avatar
stevieturbo
C**t
Full face shield required for any grinder equipment. Anything else is just crazy
Old Nov 26, 2011 | 12:22 PM
v man's Avatar
v man
Zee Germans are coming
also worth spraying petrol on the underseal as it melts it slightly and helps to remove it
Old Nov 26, 2011 | 01:35 PM
andy escos's Avatar
andy escos
Talking
did some body say grinders
i use the twisted wire wheels they are great for ripping stone guard & sealer off with out damage .
as for face shields i use this full closed eye protection with facial guard as well ,the best set up in my opinion .
http://www.ebay.co.uk/itm/UVEX-Ultra...b#ht_514wt_700
Old Nov 26, 2011 | 02:47 PM
stevieturbo
C**t
Looks good, I take it that isolates breathing from the eyes then, so they dont steam up ?
Old Nov 26, 2011 | 08:22 PM
cossiestu's Avatar
cossiestu
Is the best way a wire brush an grinder, or a heat gun an a scraper to get the worst off first? As you can tell, I've never done an underside resto!?
Old Nov 27, 2011 | 09:31 AM
stevieturbo
C**t
Never used a heat gun, but the wire knot wheel in a grinder is very effective, but take the safety mentioned very seriously.
It will be slow and time consuming, and of course very messy.
I can't really think of any easy and clean methods. Unless there are some serious chemical type strippers out there.
Old Dec 1, 2011 | 03:18 AM
griffo69's Avatar
griffo69
thanks for the replies guys, im going to order the twist cup brushes, would anyone know what thread size i need m10 or m14 grinder is a 4 inch i think
Old Dec 1, 2011 | 09:00 AM
fraser9764's Avatar
fraser9764
Iirc 4" is m10 and 4.5" is m14
Old Dec 1, 2011 | 04:57 PM
griffo69's Avatar
griffo69
bollocks ive ordered the m14 one
s1cab
Jul 26, 2018 06:11 PM
col93saphcos
Aug 7, 2015 03:21 PM
vdubo7
Aug 2, 2015 08:17 PM
