wow. it's a tight fit
just made myself a 3.5" exhaust system for my shonky saff. it's a damm tight fit.
tony measured the back pressure in my old front pipe and advised me to fit a 3.5" front pipe. so i'm goin to make a 3.5" system with side exit pipe or pipes.
The thick steel flange I took off my old exhaust. The thin stainless part came from a mate that works at a aerospace company.
Originally Posted by xr2wishy Lg
;5711287
;5711287
get it heat wrapped, will dull down the sound it it bangs around.
Please explain how a taper would be better than what I've done. I'm not against change if there is a better way top do it. I'm not a exhaust designer.
the lip on the 3" to 3.5" section will create a vortex and swirl the gas, this will cause a flow issue and hence not the best, whereas a taper is a controlled expansion of the gas and won't swirl the same, so more flow.
hey up,i am the man who made the flange adapter and the tube,if the turbo has a 3 inch housing and the adapter fits right up to that housing,then there is only 10mm of tube which is 3 inch then it goes into 3 1/2,if it was flowing the other way then a taper on the tube would of worked better,it is fiiting to a t4 turbo,so we are using the standard flange,thanx for your comment,i will keep it in mind when im making custom parts no one else is making
what im trying to say is,if the turbo housing is 3 inch and the flange is of the 3inch down pipe,then there was no other way of making the adapter,the adapter has a shoulder of around 12mm at 3 inch i/d,then it goes to 3 1/2.forming a taper would make no differance to the flow at all,if the turbo had a bigger housing then i would of made it 3 1/2 inch from the turbo
well i can cope with with the 3 downsides youv'e listed what are the other ones. ps thanks for your input.
IIRC porkie had a 4" system made by now long gone tube torque in macclesfield, he had pics on here years ago showing the taper they made.
It might be worth pming him to see if he still has a pic
steve
steve
Ever wonder why your making custom parts that no one else is making?
Great work, nice to see someone doing things right for a change
IIRC you can start to measure backpressure in a 3" system at something like 350bhp
rapidcossies sapph use to run a 3.5 or 4" downpipe (can't mind what size it was now and I wrapped the fecking thing today as it happens) splitting to twin 3" after the g.box
I don't know what power it will be I just know that when we checked the back pressure last time it was too much. The problem was either the front pipe or the silencer. I'm changing both so hopefully that should cure the backpressure issue. Who would like to design me a back box.
What he has done is probably better than a smooth taper.
And there is absolutely nothing smooth about what is exiting the turbine/wastegate.
It would be better still upping to 4" for the downpipe and then downsizing. As Rod as already suggested even around 6-700bhp, 3" isnt really much of a problem. Although again going upsize certainly wont do any harm.
But if you had only 4-500bhp or so, it would be a waste of time.
Back pressure in the exhaust really doesnt sap power as much as you think, unless it was silly.
