Harvey Gibbs 660BHP Engine And Ancillaries
Harvey Gibbs 660BHP Engine And Ancillaries,
Just come back from SCS, had a full top and tail with new oil pump, will need running in.
Engine Spec -
200 Block Nickosil Linered
Oil Jets In Block
CP Pistons
Steel Auto Verdi Rods
Standard Standard Razor Blade Crankshaft
Nick Waples Cylinder Head
8 Green Injectors
SCS Spec Camshafts
Solid Lifters
Swedish Plenum
WRC 8 Injector Manifold
Stainless Tubular Exhaust Manifold
Garrett Ball Bearing Turbo
Pectel T2 Ecu With Loom Coil Pack
Air Injectors
SCS Big Wing Sump
Please check out my website for other Cosworth Parts
www.mt-motorsport.com
Dyno Sheet Available Upon Request
Engine Spec -
Oil Jets In Block
CP Pistons
8 Green Injectors
SCS Spec Camshafts
Solid Lifters
Swedish Plenum
Air Injectors
SCS Big Wing Sump
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
