cosworth 4x4 air con
ive got a saph cos 4x4 and want to know if i take the air con off if it will it cause any problems with balance on the engine as power steering and alternator are on the other side any help will be most helpful
i wouldn't. it won't hurt anything, but i love air con. once you've had it, you can't go back to not having it.
if you do take it off, be careful ndoing any joints. let the gas out of one of the service ports (like tyre valves) slowly first (actually you should have the gas proffesionally recovered as it is a CFC and contributes to global warming, but it came out in crash right?). this gas is under pressure and can freeze you when you let it out. wear hand and eye protection.
Air conned Saph is QUITE rare. I'd sell the car and buy one of the thousands that didn't come with it. Otherwise, upgrade the IC with a modified Escy Cos one with built-in chargecooler in order to keep the air con. But it's your car at the end of the day.
I wish my 3dr Cos came with air con, as I live in Dallas, and it will be cacooned during the hot months
Suppose to use more fuel i think
Anutternutter
Aug 21, 2015 06:07 PM
charliecosworth
Aug 19, 2015 02:00 PM
Aug 14, 2015 07:29 AM
