Cam belt change pug boxer 2.0 petrol?
Old Nov 22, 2011 | 06:07 PM
Ima Racing's Avatar
Ima Racing
Default Cam belt change pug boxer 2.0 petrol?
Is this an easy job, any special tools, engine out etc etc its a single cam job 110bhp job.
Old Nov 23, 2011 | 07:41 PM
Ima Racing's Avatar
Ima Racing
Anyone? Lol
Damn in the old days if no answer in 24hrs this would be down to atleast 4 pages! Now top of page 2!
Old Nov 23, 2011 | 08:13 PM
golf699's Avatar
golf699
Default regards to your problem
there should be a hole by the gearbox half way up on the block going towards the the gear box that is a locking point for the crank on the cam it should be on the cam gear with out looking at the timing book at work i recon it should be about 10 past ont the cam put a bolt through there and a drill bit for the crank. You can replace it with out taking the engine out time wise i think its about two maybe three hours the hard part will be cracking the crank pully but if you have a half inch bar and a 22mm socket i think you can do it using the starter motor if you need any more info pm me
rex647
Mar 6, 2022 06:20 AM
dombanks
Sep 21, 2015 08:38 PM
Adam Graham
Sep 6, 2015 06:04 AM
rog
Sep 4, 2015 07:24 AM
hopper350
Sep 4, 2015 12:53 AM
