The Last bits off the Sierra. more parts/pics added 17/1/12
Old Nov 21, 2011 | 09:56 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
Default The Last bits off the Sierra. more parts/pics added 17/1/12
Passenger door, delocked, comes with clear glass and seals. handle parts have been removed, no door card
£40 collect only
Drivers door, same as above but has a mk6 escort door lock fitted. comes with 2 keys.
£40 collect only
Ultralight Atec 17", 7" front with 215/40/17 as new tyres. Rears are 8" wide 235/40/17 with as new tyres (wheels and tyres covered 167 miles)
£500 collect only, no offers
Pro alloy rad painted satin black.
£150 no offers can post for £15 extra
Hayward and Scott custom 3" exhaust and downpipe with V-band clamp
£350 - have reciept for £600 + VAT collect only
Stack boost gauge, 3 bar
£85 plus £5 postage
Stack Fuel level gauge
£70 plus £5 postage
fuel level on the right
Samco hose in black, 32mm i/d 63cm long £15 delivered
more samco, long is 27.5cm, short 9cm. £7 delivered
SFS 90 degree bend and 2 joiners 7cm long £12 delivered for those 3
90 degree plastic hose joiners x4 32mm. £10 delivered for all 4
11x 25-40mm hose clips £10 delivered for all 11
-12 90 degree fitting with oil hose 69cm long. hose ID is about 15/16mm £8 delivered
-12 straight fitting with oil hose 99cm long £8 delivered
-12 45 degree to straight coupling oil hose 56cm long £12 delivered
-12 45 degree with short oil hose23cm long £7 delivered
-3 goodridge ptfe braided hose, straight fitting one end, 90 degree the other £9 delivered
burton power brake bias pedal adjuster, unused 90cm long cable £18 delivered
2wd cosworth T5 speedo drive £65 delivered
MSD thermostat switch used for 167 miles £10 delivered
revotec sump plug adaptor m14 thread with 1/8npt hole tapped in for a sensor £12 delivered
heat sheild 300mm x 300mm, dropped on one corner £20 delivered
9x 1" rubber coated alloy P clips £10 delivered
20x 13mm rubber coated alloy P clips £12 delivered (suiable for -6 fuel hose)
18x 8mm rubber coated alloy P clips £12 delivered (suitable for -3 brake hose)
pro alloy made solid hose in black, has a -8 take off, 32mm ends £15 delivered
pro alloy made kinked hard pipe boost hose 65mm i/d £20 delivered
pro alloy made hard pipe boost hose, 55mm i/d £20 delivered
if i find anything else, ill stick it up.
all postage will be citylink express 24h
07876207885
Cheers, Dan
Old Nov 21, 2011 | 10:23 PM
J1mbo's Avatar
J1mbo
B1mbo
£350 here for rad and cooler posted
Old Nov 22, 2011 | 06:49 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
Jimbo, yes i guess i would! but check the pics of the rad first, as its not a straight forward fit for a cosworth as its basically got the mounts on upside down. but if your handy with the welder it wont be any issues lol
Old Nov 22, 2011 | 06:56 PM
J1mbo's Avatar
J1mbo
B1mbo
Ok mate no worries, sounds a mission intercooler pipes look a bit shorter than saff ones aswell and don't look like they would fit with off shelf boost pipes?
Old Nov 22, 2011 | 08:07 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
i can also supply the hardpipe/silicon hoses that were used on my setup.
ill find a pic
Old Nov 22, 2011 | 08:28 PM
J1mbo's Avatar
J1mbo
B1mbo
Cheers Fella, I'll see what the old man thinks. How thick is the core? And outlet sizes?
Old Nov 22, 2011 | 08:43 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
core is 60mm, n/s inlet is 65mm, o/s inlet is 77mm.
i bet even if you sent the rad back to pro alloy to mod it would still be cheaper than buying a new one
ic was £450, rad £250
Old Nov 22, 2011 | 08:44 PM
J1mbo's Avatar
J1mbo
B1mbo
Ok fella, that's not a lot of good for rs500 pipes either, not doing well here!
Old Nov 22, 2011 | 08:47 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
i said i can supply the pipes in the pics lol
Old Nov 22, 2011 | 09:07 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
fudgey , bit of a longshot ... you still got the manual rack ?
beef
Old Nov 22, 2011 | 09:12 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
no, i sold on ebay beef... £0.99p!
and the fucking cunt still moaned about the box being damaged by the courrier when he got it!
i just remembered i have a load of stack stuff ill add.
Old Nov 25, 2011 | 04:45 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
up ski
Old Nov 25, 2011 | 05:28 PM
snoopaloopa's Avatar
snoopaloopa
First Dibs on the stack boost gauge pending pics please mate
Old Nov 25, 2011 | 09:18 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
oh yeah forgot about the pics lol.
only one i have at the mo
Old Nov 26, 2011 | 02:29 AM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
free bump
any joy with insurance or getting the scum cunts who rammed you locked up??
Old Nov 26, 2011 | 01:19 PM
snoopaloopa
I'll give it a miss mate, cheers.
Old Nov 26, 2011 | 08:19 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
Originally Posted by warrenpenalver
free bump
I have finally received a payout from my insurance company in october, some 10 months after!
and the solicitors have a copy of the police report now, but its all gone quiet on their part really....
Old Nov 26, 2011 | 08:20 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
no worries
Old Nov 30, 2011 | 07:55 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
upski...
Old Nov 30, 2011 | 08:22 PM
COCHYN's Avatar
COCHYN
The Stack ST700 is an awesome piece of kit, mine's great! Bargain buy for anyone!
Old Nov 30, 2011 | 08:28 PM
boy-racer-1's Avatar
boy-racer-1
havent got them zetec engine mounts up for grabs atall?
Old Dec 2, 2011 | 06:50 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
already sold mate. sorry
Old Dec 7, 2011 | 07:00 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
parts sold removed from list
Old Dec 8, 2011 | 05:56 PM
JamesH's Avatar
JamesH
Dan,
Is the stack boost gauge definitely 3bar and not 30psi? Looks like it measures vacuum too? Is it 52mm?
Old Dec 8, 2011 | 07:21 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
James you are quite correct, its 30psi and does measure vac.
yes its 52mm
Old Jan 16, 2012 | 09:06 PM
DixieTheKid's Avatar
DixieTheKid
Pick-up P100 Power!
I would be interest in the scuttle and ends but thats way out of my price range. Chris
Old Jan 16, 2012 | 09:22 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
make an offer then mate, the worst i can do is say no!
Old Jan 16, 2012 | 09:26 PM
jonfoc's Avatar
jonfoc
Have you got all the sender and bits with the fuel gauge Dan?
Old Jan 16, 2012 | 09:29 PM
DixieTheKid
Pick-up P100 Power!
I dont want to offend you, whats your rock bottom price posted?
Old Jan 16, 2012 | 09:30 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
the sender was custom to the fuel tank so it went with that, but the guage itself can be callibrated to your standard sender.
Old Jan 16, 2012 | 09:31 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
well at the momnent its £125 plus £10 postage for all of it, but no one has made me an offer
Old Jan 16, 2012 | 09:34 PM
DixieTheKid
Pick-up P100 Power!
Ill have to leave it. Thanks anyway bud.
Old Jan 16, 2012 | 09:35 PM
jonfoc's Avatar
jonfoc
Bugger I have no sender in my ATL cell, I needed the lot. Have you any of the thermal sleeving left?
Old Jan 16, 2012 | 09:41 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
the orange fire proof stuff or the silver heat proof stuff?
as i have some of both lol
dixie, pm me if you like, you obviously have a maximum you can go to, so try me
Old Jan 16, 2012 | 09:42 PM
jonfoc's Avatar
jonfoc
I'll have a look at both you have. PM me some pics over please pal
Old Jan 16, 2012 | 09:46 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
ill have to get some pics of what i have tomoz mate, as i cant be arsed buggering about in the garage now as its freezing lol
Old Jan 17, 2012 | 12:42 PM
focus 4x4's Avatar
focus 4x4
still got the stack boost gauge??
what colour does it light up??
Old Jan 17, 2012 | 01:26 PM
jonfoc's Avatar
jonfoc
[quote=Fudgey;5773064]ill have to get some pics of what i have tomoz mate, as i cant be arsed buggering about in the garage now as its freezing lol[/quote
No worries pal
Old Jan 17, 2012 | 02:38 PM
robp-tt's Avatar
robp-tt
ZETEC TURBO
Do you still have the rad? If you do how wide and tall is it
Old Jan 17, 2012 | 04:24 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
yes mate, and white
[QUOTE=jonfoc;5773586]
No worries pal
will sort out pics later bud
yes, i still have it. will measure when i get home
