2wd shafts?
Old Nov 21, 2011 | 05:46 PM
WongRS's Avatar
WongRS
Default 2wd shafts?
Is there a few different types of these?! seems to be from what i can make out?
And will they work with 4x4 rear hubs?
Cheers, Dan
Old Nov 21, 2011 | 05:53 PM
dojj's Avatar
dojj
Resident Wrestling Legend
you ned 2wd stuff as the flanges are 108mm as opposed to the 4wd's 100mm flanges
Old Nov 21, 2011 | 05:55 PM
WongRS's Avatar
WongRS
Thats bent, i need 2wd hubs then?
cheers for the reply.
Old Nov 21, 2011 | 08:34 PM
dojj's Avatar
dojj
if by hubs you mean the bits the bearings sit in and the bits the calipers bolt on to, then they are the same on all the cosworth branded versions
if you mean the bits that go through the hubs and have the big fuck off nuts screwed onto them, then you need 2wd cos ones as they aren't compatibale sizewise with anything else
so, to recap:
2wd diff neds 2wd cv's and 2wd shafts bolted onto 2wd outer cv's which then go into 2wd output shafts
if you have the 4wd stuff then it's virtually the same (other than the diff ratio's, the lsd's and the shaft lengths) to every other sierra with a 7 inch diff, including the xr range
various granada's and sierra's also ran with 7.5 inch diffs which is where the shaft lengths vary from side to side 18.5 inch, 20 inch and 20.5 inch
Old Nov 21, 2011 | 08:38 PM
WongRS's Avatar
WongRS
Thats great, so basically, 2wd diff with 2wd shafts and 2wd(flanges?! are they output shafts?!) into my 4x4 hubs?
Old Nov 21, 2011 | 09:24 PM
dojj's Avatar
dojj
yes mate
these bits in teh pic are what you can keep from the 4wd stuff
the bit that goes through the middle is what you ned to find from a 2wd car
Old Nov 21, 2011 | 09:28 PM
WongRS's Avatar
WongRS
Thats great, thanks very much for you help, sir Dojj
Old Nov 21, 2011 | 09:40 PM
dojj's Avatar
dojj
no worries fella
you can even keep the beam if you like, the 2wd diff will fit with a little fettling, you simply cut out a bit of the upper mounting casting from the diff casing (don't matter as it's just a casting and you've got at least another foot of it to hold the diff in place)
Old Nov 22, 2011 | 08:18 AM
R4N SS's Avatar
R4N SS
good info there dojj
i found my 2wd shafts the other day in my garage from my moonstone 3dr - they're not for sale tho lol
Fudgey
21
Sep 30, 2015 06:19 PM
mondeomark
Sep 28, 2015 06:28 AM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
