Focus cutting out.
Old Nov 20, 2011 | 07:27 PM
ethans-dad's Avatar
ethans-dad
Default Focus cutting out.
I have a 2002 Focus 2.0 auto.
When the engine is cold, after probably 10 seconds of running it tries, and sometimes does, cut out.
When it does manage to carry on running (at very low revs, approx 4-500rpm) the traction control and ABS lights come on until it warms up and then the lights go out and it goes to normal idle speed.
This only ever happens when the Air-con is on, and so if you switch the Air-con off, it goes to normal idle speed.
Does anyone have any ideas as to what might be causing it?
I've been told that the Traction/ABS is connected to the ecu, so this might be at fault?
Cheers in advance.
Old Nov 21, 2011 | 06:30 PM
ethans-dad's Avatar
ethans-dad
Anyone?
Old Nov 21, 2011 | 07:34 PM
nevsrevs's Avatar
nevsrevs
what is it ticking over at when its warm? could be a fault on i.s.c.v or speed sensor or just a low tick over
Old Nov 21, 2011 | 08:03 PM
ethans-dad's Avatar
ethans-dad
When it's warm it ticks over perfectly.
Old Nov 21, 2011 | 09:42 PM
nevsrevs's Avatar
nevsrevs
so its a cold start prob, got to look at temp sensors and so on, or dont turn on the a.c. when its cold,
Old Nov 21, 2011 | 10:29 PM
langer's Avatar
langer
It will be the iscv this is located on the underside of the inlet manifold and held in with two 8 mm bolts, you could either take it off and clean it with brake cleaner (cheapest way) or buy a new one lol
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
stevierob
Sep 7, 2015 07:09 PM
hopper350
Sep 4, 2015 12:53 AM
