Alternatives to a SECS monitor for a Cossie?
Old Nov 17, 2011 | 08:50 PM
Karl 3dr's Avatar
Karl 3dr
Default Alternatives to a SECS monitor for a Cossie?
As title really, i've got a Secs monitor in my Sapph at the mo, and although i find it really useful, it's a bit pointless when it comes to measuring boost because the moment it sees over 2 bar it flashes up a warning
Are there any alternative monitors out there that you'd recommend??
It would have to be a simila size/fit in the same place as the SECS monitor because i dont want something that looks out of place.
Cheers, Karl
Old Nov 17, 2011 | 09:13 PM
KSA-Cossie's Avatar
KSA-Cossie
Check out this Karl
http://www.randbmotorsport.co.uk/shop/Parts.asp?ID=1
Old Nov 18, 2011 | 10:13 AM
R4N SS's Avatar
R4N SS
was just going to mention the new IECS monitors that rainbird sells, or just get a proper boost gauge
Old Nov 18, 2011 | 11:46 AM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
There's even a fit guide in this issue of Fast Ford!
Old Nov 18, 2011 | 12:13 PM
Karl 3dr's Avatar
Karl 3dr
Ok, cheers fellas, @ R4N SS, I've got a 2.5 bar boost gauge fitted already, albeit a Racetech one that I'm gonna change for one with peak recall, my problem isn't that the arcs monitor only seems to measure up to 2 bar, its that it flashes up a warning every time it sees that level of boost, I'd be happy if it didn't monitor boost at all tbh lol, I've got someone interested in buying my secs monitor if I can find a suitable replacement, does the IECS monitor read over 2 bar or is it restricted by the map sensor? I assume a 3 bar map sensor only measures up to 2 bar positive boost?
Old Nov 18, 2011 | 12:17 PM
KSA-Cossie's Avatar
KSA-Cossie
Correct karl
Old Nov 18, 2011 | 05:38 PM
martysmartie's Avatar
martysmartie
I was going to start a thread about the IECS, so far as I can tell this is just a copy of the SECS monitor as far as I can see and does EXACTLY the same job?
PS I have just watched the presentation video and it looks like the IECS can have no higher than a 3 BAR MAP sensor as well.
It looks as if it has slightly more functionality than SECS.
Martin
Old Nov 18, 2011 | 06:01 PM
foreigneRS's Avatar
foreigneRS
Testing the future
it's nothing like the SECS monitor as it works from a datastream from the ecu (like pectel monitors of old) not taking a parallel reading from the engine's sensors which may not be what the ecu is actually seeing
Old Nov 18, 2011 | 06:09 PM
martysmartie
But how comes the connections are merely soldered onto the respective pins though akin to SECS?
Plus would that mean then having a datastream enabled chip would be a prerequisite for having one?
Martin
Old Nov 18, 2011 | 06:29 PM
foreigneRS's Avatar
foreigneRS
Testing the future
My mistake, it seems to be very like a SECS monitor
Old Nov 18, 2011 | 09:36 PM
Jay,'s Avatar
Jay,
Sponsor
its actually 100% better than the secs monitor
better built quality parts
actually made supplied by a company that existed for more than 5 mins and i bet the owners at collins havnt had 3 wives 2 dogs a parrot and a goldfish die in the last week so your order will arrive
Old Nov 18, 2011 | 09:41 PM
KSA-Cossie's Avatar
KSA-Cossie
Fucking lol . Oi cunt chops where's ma heat shield btw ??!!
Old Nov 18, 2011 | 09:51 PM
Jay,'s Avatar
Jay,
Sponsor
ring me in the morn
Old Nov 18, 2011 | 10:23 PM
Cilly-jey's Avatar
Cilly-jey
looks a cracking bit of kit, i got a collins monitor 12 months ago and it arived with in 2 weeks. was happy with that. shame the iecs dont just plug in like the collins dose. then u would no what the ecu is doing
Old Nov 19, 2011 | 12:48 AM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
The IECs is also to an extent programmable for certain features eg alarms, shift lights, water injection control etc.
Also the firmware can be upgraded to accept different sensors, wasted spark etc. There have already been firmware revisions to improve it, so id expect there to be more in the future too.
Old Nov 19, 2011 | 10:47 AM
martysmartie
It's still using the same basic setup that SECS uses, i.e. merely a voltmeter measuring sensor values.
The collins monitor is totally different and superior in the fact that it's a data stream from the ECU so not only can you see what the ECU is seeing but also has features such as being able to see ignition timing values etc.
Just find it weird how people rave about the IECS like it's some mind blowing invention lol, SECS has the alarm features as well.
Martin
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
pabloXR
Sep 21, 2015 12:42 PM
