cosworth parts 2wd and small turbo
Old Nov 16, 2011 | 06:55 PM
boy-racer-1's Avatar
boy-racer-1
Default cosworth parts 2wd and small turbo
saph 2wd front crossmember £30 - sold
saph 2wd front hubs £40 - sold
saph 2wd front anti roll bar £20
saph 2wd front track control arms £20
2wd power steering pump brackets 3 peices been sandblasted and zinc plated looks better then new £40 ono
t3 turbo rebuilt with 2wd manifold £180 - sold
2 x saph gearbox mount £30 each
small turbo engine wiring loom with the distributor peice not sure what its called and coil packs/leads no longer needed £200 ono
saph 4wd inlet manifold outer peice only £20 - sold
plus postage costs
larger items will have to be collected unless you want to arrange your own courier
loads more parts to list yet
pm me for anymore details/pics
Old Nov 17, 2011 | 08:47 AM
R4N SS's Avatar
R4N SS
are the hubs in good condition?
Old Nov 17, 2011 | 10:10 AM
boy-racer-1
ok ive got some more parts to list
burton distributor brand new never fitted £130 (cost me £146 )
feul pump cradle complete with pump, filter connections and wiring which has been cut, has seen better days but is still solid enough to be sandblasted and painted £30
saph 2wd rear driveshaft not sure if this is the long or short ne yet will check later £30
saph 2wd rear calipers only no bracket genuine ford ones £40 ono
cosworth na inlet plenum for 45's £70
2wd inlet manifold injector section only has cracked on the corner where it mounts still useable though £10
2wd rear abs sensor has a slight nick out of it as you can see in picture £15
crankshaft sensor and bracket £15
pinto crankshft rods and pistons, crank needs a grind and conrods dont move freely on pistons the engine had an oil blockage so its all for spares, free to whoever wants to collect them
Old Nov 17, 2011 | 10:20 AM
boy-racer-1
hubs are fine no play in the bearings and no noise from them when turning
Old Nov 17, 2011 | 10:43 AM
boy-racer-1
Old Nov 22, 2011 | 07:06 PM
boy-racer-1
no one want these parts?
Old Nov 22, 2011 | 10:18 PM
RSGARETHW's Avatar
RSGARETHW
always working
What's the best price delivered in fuel pump cradle mate? U can keep the pump and sell it separate if you like... I just need the cradle with brackets really, no filter or pump...
Cheers gaz
Old Nov 23, 2011 | 12:44 AM
langer's Avatar
langer
Much you wanting for the crank mate? Is is 2 or 4 wd or does it not matter?
Old Nov 23, 2011 | 03:39 PM
Cosnada's Avatar
Cosnada
£30 for the dizzy sender
Old May 24, 2022 | 12:36 PM
CosoyDimas's Avatar
CosoyDimas
Default Распределитель зажигания
Юрий приветствую. Очень ищу распредели зажигания . Вы могли бы отправить его мне в Санкт-пктербуг ?
155lee
Aug 14, 2015 11:21 AM
Aug 14, 2015 07:29 AM
adam151082
Aug 11, 2015 04:50 PM
Old ford
Jul 31, 2015 06:50 AM
