throttle bodies vs bike bodies?
Old Nov 15, 2011 | 06:23 PM
rst in breaking's Avatar
rst in breaking
Default throttle bodies vs bike bodies?
how do they compare performance wise? wanting to build a nice spec pinto for my new car and wondering what route to go, want to push for around the 180bhp which from what im learning is going to cost a fair bit, thoughts and opinions appreciated, cheers
Old Nov 15, 2011 | 07:52 PM
Mark V8's Avatar
Mark V8
Early GSXR750 bodies flow enough for well over 200bhp - 46mm throttle plates and can be re-spaced as they are individual.
Later ones had extra throttle plates that will need removing.
I think the very latest ones are cast as pairs and are harder to space.
Old Nov 15, 2011 | 08:12 PM
rst in breaking
early as in around what years? not very knowledgable on these, cheers
Old Nov 15, 2011 | 08:35 PM
Darylc.'s Avatar
Darylc.
49cc superbike!
Slightly related question: What's the advantage of bike bodies over normal throttle bodies? Thanks.
Old Nov 15, 2011 | 09:00 PM
focus2l's Avatar
focus2l
yamaha r1 bike carbs will easyly run eninges ova 200bhp
Old Nov 15, 2011 | 09:32 PM
Mark V8's Avatar
Mark V8
Sorry I can't be of more help, but from memory the first injected ones were from around 1998
I fitted a set to a 2.3 RS2000 16v and got just over 200bhp out of it.
Old Nov 15, 2011 | 09:35 PM
WongRS's Avatar
WongRS
Funnily enough we have been having this same conversation at work today, a lad has a 4 door mk with a hot 2.2 pinto in, on 45's, and he wants to go bike bodies as the carbs are a frigging nightmare.
I'll show him this.
Chester sports cars bike throttle body conversions dont look bad
Old Nov 15, 2011 | 10:07 PM
rs clint's Avatar
rs clint
insane
got gsx r750 carbs on my mk2 2 litre pinto runs well revs well got it in one of the threads the twin carbs always need balancing
Old Nov 15, 2011 | 10:23 PM
rst in breaking
cheers guys
Old Nov 16, 2011 | 09:36 AM
~nomad~'s Avatar
~nomad~
My old fiesta now has st170 on I think AEG ITBs and standard cams made just under 170bhp iirc. Having a set of piper cams made up and the st170 exhaust manifold modified which should see it over 180 hopefully. Thats a fairly cheap conversion, prob cost Ł1500 all in. Made about 210 with the nitrous.
Old Nov 16, 2011 | 09:40 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
On an asthmatic 8v like a pinto, pretty much any bodies are going to flow far better than even a well worked head.
Old Nov 16, 2011 | 09:53 AM
~nomad~'s Avatar
~nomad~
totally missed the word pinto there
get the pinto out and a better engine in!
Old Nov 16, 2011 | 09:54 AM
BIL N KEL's Avatar
BIL N KEL
My brother is currently fitting bike carbs to his rs 2.3k. He's using 1300 carbs. How did you plumb the fuel system? I've been told that the fuel pressure needs to be around 4-5psi. Any help much appreciated
Old Nov 16, 2011 | 10:17 AM
rs clint's Avatar
rs clint
insane
i run mine on 2 - 2.5 psi
Old Nov 16, 2011 | 10:40 AM
Porkie's Avatar
Porkie
None.
They are just cheaper.
Old Nov 16, 2011 | 10:43 AM
Chip's Avatar
Chip
Originally Posted by Porkie
one.
Fixed!
Old Nov 16, 2011 | 11:50 AM
Mark V8's Avatar
Mark V8
I used throttle bodies and injection, but from memory bike carbs do not like too much pressure. 2-3 psi is more than enough.
Old Nov 16, 2011 | 11:57 AM
Porkie's Avatar
Porkie
Originally Posted by Chip
Fixed!
valid!
Old Nov 16, 2011 | 12:11 PM
rs clint's Avatar
rs clint
insane
as i put in my post i should know as i am running them any higher and you over fuel them
Old Nov 16, 2011 | 12:12 PM
Darylc.'s Avatar
Darylc.
49cc superbike!
None.
Cheers thanks
Old Nov 16, 2011 | 12:16 PM
gjh's Avatar
gjh
I'm sure I read bike carbs can be restrictive once you have the engine tuned fairly highly, but I imagine for the 180 or so horsepower your looking for they should be fine.
Old Nov 16, 2011 | 12:43 PM
Zetec_mk4_XR3i's Avatar
Zetec_mk4_XR3i
here's my experiences with each:
I run Weber Alpha throttle bodies on my car, on an ST170 engine. Engine is standard and it has a meaty 4 branch and full stainless and it made 193 bhp last time on rollers. Its 100% reliable, brilliant on fuel and lovely to drive.
We converted a mates XR2 to a 2.0 silvertop Zetec with the Chester Sports Car kit - the kit is very good and the car made 167 bhp, again with a standard engine and big Ashley 4 branch. Its a track car so cant comment on the road but its nippy enough and takes a lot of abuse!
Sorry dont have any Pinto experience but have you considered a Zetec mate? From your sig etc you obviously know your stuff!
Old Nov 16, 2011 | 07:32 PM
locosaki's Avatar
locosaki
Bike bodies are perfectly fine to use but have to be fitted to a good inlet manifold and fixed rigidily. Cutting up a manifold then joining with silicone pipe and a couple of jubilee clips is a complete waste of time as the bodies will be for ever going out of balance and the inlet tract will be anything from ideal.
I have used bike carbs on a C20XE and the results were mariginally better than standard but the inlet manifold was rough.
Old Nov 16, 2011 | 07:57 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
it was you that inspired me to sling a set on my old escort lol
i think its a gixxer k3 ones??
you can space the gixer ones with studded bar and nuts, but i made some drawings and got my dad to machine some alloy spacers up to look neat.
anyway, some pics! mine made circa 180bhp on the tbs, st170 manifold and secs s8 ecu
mine had the secondry butterflys that i removed and painstakingly threaded some silicon tube in to plug the holes
i used the original injectors from them to have some blanks machined with a straight through hole, this was used for the brake servo vac
on a 2.0l zetec they had to be spaced about 17mm iirc, so had to mod the linkages
chopped up a std alloy zetec inlet and had grooves machined in and neoprene gaskets made
[IMG]http://img.photobucket.com/albums/v193/fudgeass/105_0937_0001.jpg
[/IMG]
modded the std fuel rail and used std cossie injecotrs that were end fed, used with a mk2 astra sri fuel rail that was near enough bang on for the spacing!
universal K&N airbox from rainbird
finished engine!
in the car
i did have a vid somewhere of it in action, the noise was amazing. but i cant find it
Old Nov 16, 2011 | 08:38 PM
wide ka's Avatar
wide ka
I ran busa ones on my engine, it made more power than other engines with same spec, but I had issues with light throttle, as there designed for I bike thevsetupndiifers so it more on and off I found in the car
Not ideal in that respect, but half price
Old Nov 16, 2011 | 08:45 PM
cossie350's Avatar
cossie350
I have Busa bodies on my 205, S16 engine, its bog standard, running on a emerald ecu, 4 injectors and makes 200bhp. Ive never seen a standard engine on Jenveys make this much always seem to be 190bhp max.
Im confident they would flow at least another 20bhp.
Oh and its on a cut down manifold.........
Old Nov 16, 2011 | 08:47 PM
Mark V8's Avatar
Mark V8
I managed to use the progressive throttle linkage from the RS2000 to help with small throttle openings.
Edit... if you like a good argument on the subject
https://passionford.com/forum/restor...r-mounted.html
Old Nov 17, 2011 | 10:50 PM
rst in breaking
gone off zetecs as always worying about pump letting go as had it once already lol, once built im hoping i dont have to worry about it lol. just went and bout some jenvey 45's to take car of it. thanks for info guys
Old Nov 18, 2011 | 06:37 AM
rs clint's Avatar
rs clint
insane
mine are fixed with silicone hoses and jubilee clips run fine very sturdy definitely dont go out of balance
Old Nov 18, 2011 | 11:19 AM
wide ka's Avatar
wide ka
same here, mine were fine like this for 13k
Old Nov 19, 2011 | 12:52 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
So, could these be used on a turbo application? Am I right in thinking that as long as the CSA (cross section area) of the body is larger than the CSA of the inlet tract, then it will not cause a restriction?
Old Nov 19, 2011 | 01:42 PM
Mark V8's Avatar
Mark V8
The GSXR ones are fine with a turbo, I also fitted a set to my turbocharged FZR1000 after getting no where with blowing through carbs
Old Nov 19, 2011 | 02:07 PM
SiZT's Avatar
SiZT
As others have said, the only issue with bike bodies is that they open more on light throttle openings compared to car specfic tb's
Old Nov 19, 2011 | 02:12 PM
RWD_cossie_wil
The opening found be sorted with a progressive cam lever, much like the STD cosworth one I would imagine?
Old Nov 20, 2011 | 02:39 PM
rs clint's Avatar
rs clint
insane
bought some cone filters for bike carbs when flat out the engine was holding back like a rev limmiter adjusted timing and fuel pressure still the same took off filters smooth as silk no holding back wondering if it was due to airflow
Old Nov 20, 2011 | 04:07 PM
Dlatch!'s Avatar
Dlatch!
any more info on this? would love to fit one to my gsxr tb's
Old Nov 20, 2011 | 05:40 PM
Mark V8's Avatar
Mark V8
If you check out the pic I posted you can see the aluminium adaptor bolted to the side of the throttle body to hold the progressive linkage.
I will check to see if I have any drawings but don't think I still have it.
Old Nov 22, 2011 | 05:01 PM
Dlatch!'s Avatar
Dlatch!
thanks mark
the drawings would be handy but i don't have access to the machinery to make a quality bracket like you have done there i was thinking of making a new snail cam as per original but to give some more control at the start of the butterfly opening.
should be able to at least improve it that way i hope as they are very sensitive
mk3ste
Oct 17, 2021 10:09 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
sridgett
Oct 1, 2015 07:30 PM
