Squeak / squeal when disengaging starter motor?
Old Nov 14, 2011 | 07:11 PM
RichieST's Avatar
RichieST
Default Squeak / squeal when disengaging starter motor?
Noticed my car makes an odd noise when I start it, only does it when it's cold, is fine when warm.
The starter turns and the engine fires up fine, but when you let go of the key the starter makes almost like a high pitched metallic screech, I guess you could relate it to finger nails down a black board. Only does it for a split second as starter disengages.
Any idea what it could be? Starter on its way out or flywheel ring gear knackered
Rich
Old Nov 14, 2011 | 10:39 PM
martysmartie's Avatar
martysmartie
Starter motor I would say, I should think the "Dog" isn't disengageing from the engine when it should hence the sound of it being spun by the engine.
Martin
Old Nov 14, 2011 | 11:50 PM
12340987's Avatar
12340987
My focus does this too, when cold too, just sticky starter motor, early signs of imminent failure
Old Nov 15, 2011 | 12:32 PM
mechanic28's Avatar
mechanic28
shaft has prob got contaminated with clutch dust or something like that tke it out of give the starter a clean
Old Nov 15, 2011 | 06:04 PM
RichieST's Avatar
RichieST
Cool cheers guys will whip the starter out and go from there
Old Nov 15, 2011 | 06:06 PM
Neil Clark's Avatar
Neil Clark
Wifes golf did it for 5 years, always started and is still going strong a year after we sold it
Old Nov 16, 2011 | 04:14 AM
Take the starter off and give it a good clean.Clutch dust could be causing the noise.
Old Nov 16, 2011 | 06:53 AM
Paynee's Avatar
Paynee
Is this not a sign that DMF is on its way out, my pal had something similar on his transit and it transcribed the DMF was starting to go, also started to get a little vibration. Also i had a mondeo which made a similar noise and that had recent had DMF and clutch before i got it, i am led to believe that when these flywheels start to fail they can wear the starter out aswell.
Hopefully cleaning your starter up sorts it.
bobsworth
77
Mar 24, 2016 09:30 PM
A.t.p
Oct 23, 2015 07:54 PM
cossie362
Oct 11, 2015 03:53 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
marky_g
Sep 12, 2015 04:26 PM
