Perspex window help
Old Nov 12, 2011 | 05:48 PM
COLEYST200's Avatar
COLEYST200
Default Perspex window help
Can any one tell me wot tipe of perspex is use on car windows as im not going to pay £350 for a set of window for my focos when i only wont the rears so im hopping to make my owne rear windons but the fing is theres a lot of diforent types . Im been looking at using Acrylic Perspex sheet plastic 4mm thick
Old Nov 12, 2011 | 07:02 PM
Rs1's Avatar
Rs1
You could use... lexan excel, 4mm(min. to pass msa).
Have a spy through this site......
http://www.theplasticshop.co.uk/poly...ck-3096-0.html
Dont use perspex.
Old Nov 12, 2011 | 07:09 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Lexan is good stuff, it'll get scratched though.
Old Nov 12, 2011 | 07:19 PM
COLEYST200's Avatar
COLEYST200
Dont use perspex.
A big thanks for that info mate that will help me a lot in sorting them out
I do no that most plastics will scratch but if you no of a brand that is better at not scratching please let me no so i dont wast £££ on uver stuff when theres better stuff out there . thanks for your help
andy escos's Avatar
andy escos
perspex is the cheapest & most easily marked then there is polycarbonate which is a bit more scratch resistant ,then you got lexan which is the most scratch resistant .
here you go Ian
http://www.theplasticshop.co.uk/lexa...2mm-thick.html
Old Nov 12, 2011 | 07:21 PM
COLEYST200's Avatar
COLEYST200
top man Andy for that
iv been on EBAY and im looking at getting this stuff
http://www.ebay.co.uk/itm/LEXAN-EXEL...item1c1feb6adf
Old Nov 12, 2011 | 07:30 PM
dug112y's Avatar
dug112y
passionford pro
you can get it with a coating on to stop it scratching...margard i think it is. its worth it as they scratch to fuck .
Old Nov 12, 2011 | 07:35 PM
stu21t's Avatar
stu21t
ive got lexan on the 5.
when they got scratched i just used a mild cutting compound (watered down g10)and polish and it brought them up like new.
by polishing them it also stops the inside steaming up and water bead off the outside
Old Nov 12, 2011 | 08:17 PM
RONNIE AMIS's Avatar
RONNIE AMIS
When building my car I got the rear quarters and screen from plastics4performance. Then couldn't warrant spending 200 quid for the fronts so I got a couple of sheets of lexan off of eBay. It does scratch a bit easier than the coated stuff but as said just polish it out
Old Nov 12, 2011 | 08:19 PM
COLEYST200's Avatar
COLEYST200
thanks for all the help you lads have put my way
chowfornow
14
Jan 5, 2019 09:01 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 1, 2015 06:53 PM
cossie330
Sep 27, 2015 04:13 PM
