big up stu & msd
got a chip from stu at xmas
just fitted it and the t34 .. power delivery is soo smoooooth ... running 20 psi at the mo so have to turn it up a bit more
would also like to thank nath who diagnosed my snapped blade on the exhaust turbine over the fone ... also the wastegate was stuck shut solid
but its alive again so im happy
just fitted it and the t34 .. power delivery is soo smoooooth ... running 20 psi at the mo so have to turn it up a bit more would also like to thank nath who diagnosed my snapped blade on the exhaust turbine over the fone ... also the wastegate was stuck shut solid
Originally Posted by Stu @ M Developments
You will find it told you all that in the instructions that came with it Pete
Thanks for the kind words
no probs stu .. the old setup felt very raw , a couple of people would not beleive that it was a standard turbo ..
this feels alot smoother ... plus the turbo is a bit less stresed
SMILER258
Sep 28, 2015 09:04 AM
