Engine, head and gearbox...
Complete cossie engine.....
Unrun completely rebuilt bottom end.
205 block
7.5:1 Mahle pistons with valve cutouts (.5 oversized)
Reground crank
Big wing sump
New oil pump
Water pump
New ACL bearing set
New little ends
ARP big end bolts
ARP head bolts
Sorry haven't got a massive amount of pics...
Plus
Std complete cylinder head and cams
£2000 the lot...
Also a 2wd gearbox in excellent condition...
£300
CheeRS
Steve
Located Hertfordshire
07990 811886
205 block
Reground crank
Big wing sump
New oil pump
Water pump
New ACL bearing set
New little ends
ARP big end bolts
ARP head bolts
Plus
£2000 the lot...
£300
CheeRS
Steve
07990 811886
ekjim
Aug 17, 2015 08:57 PM
