Is a focus Rs head same as a zetec blacktop head ?
The whole RS engine is the same as a standard black top, the only differences are pistons, rods, cams and exhaust valves. The parts that bolt around it are different but share the same bolt patterns.
Thanks for the info guys.
I've bought a complete frs engine tonight.
I'm a bit worried that the bell housing bolts look to be different to my zetec bottom end.
Anyone know for sure if my s2 rst gearbox will fit ok ?
you can use an escort rs turbo gearbox, but need to change flywheel to an 1800 one and make sure cps sits properly as that may also need changing along with the holder.
most the fwd ford gearboxes since 1980 interchange upto the duratec or any non ford developed engine (yamaha, duratec etc)
salsheikh
Alloy wheels and ICE for sale
Jul 30, 2015 08:45 PM
