Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
Insulating garage??
Old Nov 7, 2011 | 01:55 PM
cutch's Avatar
cutch
Series 1 4x4 cossie
Default Insulating garage??
I have a double garage on the side of the house, i can get into it from the house and its great, love it, only problem is its now getting cold and i cant be arsed going out there when its freezing so how can i sort this out.
Is there something i can put round my garage door to stop the drafts coming in without affecting the door swinging up? Also is there anything i can put on the door to insulate it from the outside, flat foam insulation cut to size?
Old Nov 7, 2011 | 03:07 PM
james kiely's Avatar
james kiely
cutch you could cut 1inch kingspan to shape and fix it to the inside of your door between the structural bracing .
due to the action of the door it will be hard enough to draught proof unless you split it between the inside and outside ,alternatively get a good heavy cutrain that you can draw across the door when its closed
Old Nov 8, 2011 | 10:58 PM
nuttynil's Avatar
nuttynil
RS nutta
You can get a draught excluder for the bottom of the door and why dont you put some thick loft insulation on the back of the door and cover it in .neil
Old Nov 13, 2011 | 06:00 AM
gus's Avatar
gus
yeah i was thinking of using kingspan on the back of door, then securing in with sheet of hardboard
Old Dec 21, 2011 | 04:20 PM
MikeR's Avatar
MikeR
Whats this Kingspan stuff? is it expensive and does it fit on the back of standard ridged doors?
Mike
Old Dec 21, 2011 | 04:25 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Mike
Its rigid fibreboard that is really easy to work with, its mega lightweight and has no strength or anything but is very good at insulating.
Its kind of like a halfway house between wood and polystyrene effectively in terms of its material properties.
Normally about an inch thick although available in loads of difference thicknesses.
Have a look in your local DIY place, they'll have something similar, although it might not be that specific brand.
Old Dec 21, 2011 | 04:45 PM
MikeR's Avatar
MikeR
Thanks for that, l have X-Therm in the roof of my garage and between the floor (boarded out roof) and that works great but have wanted to do the garage doors for a while
Mike
Old Dec 21, 2011 | 05:24 PM
james kiely
mike xtratherm and kingspan are the same and comes in 8x4 sheets
Old Dec 21, 2011 | 06:04 PM
MikeR's Avatar
MikeR
Hi James, i guess the stuff for the garage door is self adhesive though isn't it?
Mike
Old Dec 21, 2011 | 06:13 PM
Chip's Avatar
Chip
Mike
Not that I have seen.
Bit of thick double sided tape would work though im sure as its so light, or even a bead of sealant, but ive only personally used it where Ive battoned it on or similar
Old Dec 21, 2011 | 06:36 PM
james kiely
their isnt a specific insulation for a garage door mike ,but as chipe said due to it being very lightweight double sided tape would adhere it to your door without a problem .
Old Dec 21, 2011 | 06:49 PM
saph4be's Avatar
saph4be
kingspan will glue to most sufaces with spray on glue!
Old Dec 22, 2011 | 01:06 PM
RickyLee53's Avatar
RickyLee53
No matter how well insulated you still need a heat source for it to get warm. A space heater will warm the garage in 5 minutes.
Old Dec 22, 2011 | 01:11 PM
james kiely
what type of glue, any particular make to look out for mate ?
Old Dec 22, 2011 | 01:51 PM
dojj's Avatar
dojj
Resident Wrestling Legend
spray on carpet glue seems to be a good choice
Old Dec 22, 2011 | 02:11 PM
D-Sport's Avatar
D-Sport
hey james
have a great xmas man, might pop up to you guys over xmas if im upthat way.
im looking at my garage now as ts cold etc but im looking at putting in a boiler like i have for the house (indoors) which sends out warm air, was talking to a guy in wexford this am and for my garage (45 x 30) it will cost me around 1300 euro but will be on a timer so i can have it on when i like wiithout being there, want to keep the cars in good order,
btw what price is an 8x 4 sheet of that stuff
Old Dec 22, 2011 | 05:10 PM
james kiely
hi dave
happy xmas to you too mate
i will give you a buzz tomorow
ps a 25mmsheet is roughly 20 euro dave ,50mm 30 euro etc
Old Jan 7, 2012 | 06:18 PM
MikeR's Avatar
MikeR
I hate to sound like a total muppet but l can not find the stuff you folks are on about, can somebody please post up a link? I have done B&Q and can find it,
Also is regular caulking ok to seal the floor edges to stop bugs and shit coming in?
Thanks
Mike
Old Jan 7, 2012 | 06:35 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
Thanks
Mike
Try your local builders merchant fella.
D.
Old Jan 7, 2012 | 06:46 PM
MikeR's Avatar
MikeR
D.
I have been into Travis Perkins and not found it either,
Thanks
Mike
Old Jan 7, 2012 | 06:50 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
Thanks
Mike
Strange,would've thought they could have pointed you in the right direction
Would suggest jewsons but you'd best be lubed up before you go...
Try an independent builders merchant,have to admit I've never seen it in Travis whenever I been there for wood
Old Jan 7, 2012 | 08:49 PM
dojj's Avatar
dojj
Thanks
Mike
think of a sheet of polystyrene, with a foil backing on one side and you get the picture
it will come in various thickness's and sizes so you could be able to buy a sheet that it 100mm thick and 1200mm x 2400mm which you then chop up into bits with a wood saw to fit the spaces between your joists/rafters
Old Jan 8, 2012 | 10:23 AM
MikeR's Avatar
MikeR
Have a lady done that Dojj, this is for the garage doors
Mike
Old Jan 8, 2012 | 10:48 AM
gouch1's Avatar
gouch1
load of stuff on the market for this even kits
http://www.google.co.uk/search?q=gar...w=1152&bih=721
gambo08
Feb 4, 2016 10:49 PM
gcfcos
59
Oct 6, 2015 05:04 PM
rsguy
44
Sep 29, 2015 03:29 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
