Just had my engine running today for w while, it ran fine apart from a bit of a missfire so i stopped the engine and took the plugs out to clean them, just with a wire brush and a cloth as you usualy do, put them back in (Firind order is right btw) and it just wouldnt start or even fire!, fuel is ok as ive had the plugs out and they are wet and there is a good spark, any ideas anyone? CheeRS in advance. pete
try the main ht lead,the one from coil to dizzy,had this trouble a few times,you canget spark to all plugs,but just not enough so it wont turn over,try changing it see if that works.
Got new plugs today, had to settle for bosch as motorfactors didng have ang of those NGK,S in stock, its running now but still has a missfire under 2000 rpm and plugs were very sooty/black after running for 5 mins and also it smells very ritch
