rs2k mkd tarmac rally car
Old Nov 6, 2011 | 07:18 AM
ryan81's Avatar
ryan81
Default rs2k mkd tarmac rally car
Selling everything you nedd to own and work on a rally car
firstly the car , spent alot on this car over the last 12 months to get it working ,
1993 Escort rs 2k tarmac rally car (mk6 Front)
mba ecu / race loom
2.0 16v
new braided fuel lines
new water pump
new timing chain
new guide
titanium plugs
magnecor leads
new lower chain
new guides
new oil filter
new gaskets intake /out take
samco hoses
manifold egr removed
de cat pipe
quaife straight cut gear box
quaife lsd
new oil
motorsport drive shafts
new stg 3 oranic clutch
rose jointed botom arms
gaz coilovers
bushed all through
front and rear strut brace
multi point bolt in cage triangulated to strut tops
ap 4 pots
new rotors
new pads ds2500
cosworth rear calipers with mechanical back up
new discs
new pads ds2500
mechinacl handbrake with cables
hydraulic hand brake vertical
new master brake cylinder
braided brake lines
oil pressure gauge
fuel pressure
water temprature
large rev counter in normal place
fuel pump switch on/off
switch for lamp pod / relays dipped beam set up
new pull cords
new steering columd adjustable
new boss
new sparco suede steering wheel
omp pedals
lexan windows with sliders
new battery red top
2013 harnasses
2015 seats
2x hand held fire ext
1x mechanical engine bay / footwell
map pockets
map light
potti light point
dunlop 200/585/R15 CR311 x22 drys
and a set of wets 9 rs 2000 alloys
bonnet pod with 2 fogs / 2 driving lamps , spare heads , block , gearboxs , lights ,boots , doors , bonnets, gearboxs, drive shafts
work shop tools is this
http://www.teng.co.uk/tcmm1001n-teng...it_1324_pd.asp
6 axle stands, low entry race jack , engine stand , engine crane , 50l compressor , 2small hyd jacks, bench vice ,da sander , compound polisher ,bench grinder / wire wheel,
and anything else lying around the shed thats to do with the car
£7250
Old Nov 6, 2011 | 07:19 AM
ryan81's Avatar
ryan81
Old Nov 6, 2011 | 12:57 PM
v man's Avatar
v man
Zee Germans are coming
alot of car and spairs for the money
bet it costs alot more to build
glwts mate
Old Nov 6, 2011 | 06:40 PM
ryan81's Avatar
ryan81
glwts mate
yeah it did
few more things to add that i forgot
new head bolts
new hyd plunger
5 th dunlop spare
bottle jack
ok/sos board
first aid
safety triangle
brillant car i just want rwd fun
Old Dec 11, 2011 | 08:22 PM
ryan81's Avatar
ryan81
Old Dec 14, 2011 | 02:54 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
what rear beam is on it? Just interested as some had cosworth stub conversions.
Old Dec 18, 2011 | 10:46 PM
ryan81's Avatar
ryan81
rs2k rear beam
Old Apr 30, 2012 | 07:54 PM
ryan81's Avatar
ryan81
Old Apr 30, 2012 | 08:18 PM
RS Grant's Avatar
RS Grant
Made in Scotland
Christ, that's some size of clearout mate... good luck with the sale.
Cheers,
Grant
Gary @ RS CLASSICS
11
Sep 10, 2015 06:49 AM
matman
Sep 9, 2015 05:45 PM
Shows & Track Days
Aug 26, 2015 05:11 AM
Shows & Track Days
Aug 15, 2015 06:25 AM
allye
Alloy wheels and ICE for sale
Aug 11, 2015 09:49 PM
