Cosworth bits & bobs
Old Nov 2, 2011 | 07:38 AM
BRAMMER's Avatar
BRAMMER
Default Cosworth bits & bobs
payment by paypal (GIFT), cheque or cash - all prices are posted
Escort Cosworth lambda sensor in perfect working condition - £32.00
Blue silicon hose Brand new 2wd - header tank to Turbo hose - water pump to metal water pipe hose - thermostat housing to Turbo hose - £20.00
4x4 Sapphire & Escort Cosworth dip stick brand new bought by mistake - £16.00
SFS silicon hose TB - Intercooler hose inc DV - standard Cosworth size, very good condition - £20.00
MSD cam spacer for using 4x4 cam in 2wd head - £6.00
Goodridge AN4 90 degree teflon fitting in silver - £8.00
Goodridge AN3 - 1/8 BSP adapter - £3.50
Brand new Head bolts (for Early type 3dr Cosworth with small 21.5mm washer) £27.50
Std 2wd Exhaust cam BD08 spec good lobes - £30.00
Cosworth aftermarket breather fitting inlet side (removes kidney box) - £10.00
Cosworth Genuine big end bolts - £15.00
Cosworth little end rod bearings brand new 1/2 price - £25.00
Coil bracket - £7.00
Cometic reusable gaskets inlet manifold gasket and the turbo gasket is a metal item not the poor material one that breaks up - were used on the last engine but did less than 900 miles - ok reusable condition - £12.00
Cosworth PAS cooler pipe - with all screws and bracket - £17.50
Old Nov 2, 2011 | 09:47 AM
R4N SS's Avatar
R4N SS
i think i will need some fittings for my pipes but have no idea on size or anything
Old Nov 2, 2011 | 11:27 AM
Rob Virgo's Avatar
Rob Virgo
I'll have manifold studs please
Old Nov 2, 2011 | 04:07 PM
BRAMMER's Avatar
BRAMMER
You would have to add an extra £1.50 if your outside the UK mate
if you want them pm me your details and i will send paypal address
Old Nov 2, 2011 | 04:08 PM
BRAMMER's Avatar
BRAMMER
What pipes are you needing doing and will tell you what you need, i may not have them here for sale but then you'll know
Old Nov 2, 2011 | 04:53 PM
RSGARETHW's Avatar
RSGARETHW
always working
brammer have you got a piccy of the oil feed adaptor please mate
Old Nov 2, 2011 | 05:50 PM
Sta1n1's Avatar
Sta1n1
whats the spec for the bell ? what disc`s are it for ?
Old Nov 2, 2011 | 06:47 PM
kmol468's Avatar
kmol468
Ill take the ARP Flywheel bolts. PM sent
Old Nov 2, 2011 | 08:50 PM
BRAMMER's Avatar
BRAMMER
It's the standard adapter that comes on the car that the oil feed and the sensor screw in to
the bells is off a GrpA car and has asphalt written on it - not sure on the materiel but it's light.
Has been fitted to a 330mm rotor in the past - depth is 25mm
what i will do is get sizes and post them up - it's a cheap way to get a set of bells as you would just need someone to knock you one up identical
Sold to you
Old Nov 2, 2011 | 09:52 PM
RSGARETHW's Avatar
RSGARETHW
always working
Thanks mate but thought it was slightly different, many thanks anyway
Old Nov 3, 2011 | 04:37 PM
R4N SS's Avatar
R4N SS
i need fittings for header tank pipes and bailey breather pipes off the top of my head.
wont really know for sure until the engine and ancilliaries are being built up (which hopefully will be within a few weeks time)
Old Nov 3, 2011 | 05:10 PM
BRAMMER's Avatar
BRAMMER
AN10 for all breather apart from return to inlet side which is AN12
Header tank, not sure as I never bothered as mine goes into a turbo cooler so pipe sizes step down in size
Old Nov 3, 2011 | 05:18 PM
R4N SS's Avatar
R4N SS
I'll have the an10 fittings and the remote oil filter thingy
Pm me ur paypal addy please
Old Nov 3, 2011 | 05:35 PM
BRAMMER's Avatar
BRAMMER
Someone said they were having it so waiting to see if they send the money, if nothing by tonight then yours Ran
Old Nov 9, 2011 | 03:52 PM
BRAMMER's Avatar
BRAMMER
Some new bit's added
Old Nov 9, 2011 | 05:00 PM
kmol468's Avatar
kmol468
Flywheel bolts arrived today - cheers for the hassle free sale.
Good luck with the rest of the parts.
Old Nov 9, 2011 | 08:15 PM
BRAMMER's Avatar
BRAMMER
Cheers mate I'll follow the feedback up tomorrow
Old Nov 9, 2011 | 08:26 PM
RSGARETHW's Avatar
RSGARETHW
always working
Brammer is this the oil pressure gauge adaptor mate?
If it is send us your PayPal details
Cheers gaz
http://www.burtonpower.com/lma011.html
Old Nov 10, 2011 | 05:02 PM
BRAMMER's Avatar
BRAMMER
Cheers gaz
Sorry mate you have the wrong part it's this one that crews into the T and the hose attaches to
Old Nov 10, 2011 | 08:26 PM
RSGARETHW's Avatar
RSGARETHW
always working
No worries
Old Nov 11, 2011 | 07:45 PM
DAN-Saff's Avatar
DAN-Saff
Is the bd08 a 2wd or 4x4 cam and is it new? And how much is postage?
Dan
Old Nov 11, 2011 | 11:19 PM
BRAMMER's Avatar
BRAMMER
2wd and not new but fine to use, was in my old engine running perfect
Old Nov 13, 2011 | 09:24 AM
BRAMMER's Avatar
BRAMMER
more parts added
Old Nov 18, 2011 | 01:44 PM
BRAMMER's Avatar
BRAMMER
List updated
Old Dec 26, 2011 | 09:47 PM
1300gt's Avatar
1300gt
Default clamps
Hi,
I will take the x2 104mm - 112mm mikilor boost clamps please chap if you still have them?. what will you do them for delivered please ?
Old Dec 27, 2011 | 11:44 AM
M88RT J's Avatar
M88RT J
have you still got the nimbus heat sheilds ?
Old Dec 29, 2011 | 02:37 AM
BRAMMER's Avatar
BRAMMER
Yes mate pm sent
Old Dec 29, 2011 | 07:35 PM
1300gt's Avatar
1300gt
Payment sent
Old Dec 30, 2011 | 05:19 PM
s2builder's Avatar
s2builder
Hello, is the oil feed adaptor still for sale?
Old Dec 30, 2011 | 06:25 PM
BRAMMER's Avatar
BRAMMER
Originally Posted by 1300gt
Payment sent
Parts sent
Yes do you want it?
Old Dec 31, 2011 | 06:43 AM
s2builder's Avatar
s2builder
Yes i want it. Is it possible to send it over to belgium?
Old Dec 31, 2011 | 12:41 PM
BRAMMER's Avatar
BRAMMER
pm sent
Old Dec 31, 2011 | 01:39 PM
s2builder's Avatar
s2builder
ok thanks! pm'd back.
Old Jan 2, 2012 | 06:03 PM
1300gt's Avatar
1300gt
Cheers received mate,
Old Jan 2, 2012 | 08:58 PM
cossiedad's Avatar
cossiedad
Am interested in the nimbus shield? Any pics of it fitted to show how it looks on?
Old Jan 3, 2012 | 06:20 AM
BRAMMER's Avatar
BRAMMER
Old Jan 3, 2012 | 06:26 AM
JamesH's Avatar
JamesH
Chris, can the nimbus shield be reshaped without it breaking/splitting?
Old Jan 3, 2012 | 08:57 PM
BRAMMER's Avatar
BRAMMER
Yes James, not sure if it would leave crease marks thought but it can be bent in any direction
Old Jan 4, 2012 | 06:35 AM
JamesH's Avatar
JamesH
I'll take it as long as there's only a couple of quid for postage?
Old Jan 4, 2012 | 09:37 AM
BRAMMER's Avatar
BRAMMER
Pm sent
