bleeding brakes issue ?
Old Nov 1, 2011 | 07:51 PM
scoooby slayer's Avatar
scoooby slayer
Default bleeding brakes issue ?
i have new flexi hoses, new 3/4 bore master cylinder and fully rebuilt calipers, i bleed til theres no air then go to next wheel and abit of air bleeding til clear then back to first wheel and air again ?
the pedal almost hits the floor first pump then feels good after that until left for a few seconds then hits the floor again first pump ?
its like there a bit of air in there just trapped maybe ?
i can see no visual leaks anywhere ?
its only front brakes rears are blanked off for now, its only a single entry system on a kit car with no servo, so only running 2 short pipes to front wheels, really baffled by it the brakes are useable but shit tbh
im not to sure what to do ?
Old Nov 1, 2011 | 08:02 PM
dojj's Avatar
dojj
Resident Wrestling Legend
because you've blanked off the rears, the system should be pushing fluid to the rears first if int's as a normal conventional set up
reconnect the rears and see what happens as i think on the lift it's drawing air back in from somewher, even perhaps from inside the resivour
Old Nov 1, 2011 | 08:19 PM
jamie956's Avatar
jamie956
have you tried a vac bleader there the best thing since sliced bread, i have a old range rover and thats an arse to do its the only thing that will blead it,
if not fill the master cylinder to the top and leave one blead nipple open for a good few hours to let some fluid run through under gravity try on both sides just keep the res toped up.
Old Nov 1, 2011 | 08:21 PM
scoooby slayer
theres only 1 outlet on the master cylinder, rears are just blanked on the t piece so wont affect it.
yatta
May 21, 2016 10:31 PM
pabloXR
Sep 21, 2015 12:42 PM
wattie
Sep 16, 2015 11:34 PM
The Enigma
Sep 12, 2015 10:12 PM
focus2351
Sep 9, 2015 09:33 PM
