Ford Fiesta 2005 Fuel Injectors
Hi all. im pretty new to this forum so here goes.
I had noticed a random tapping noise, which randomly appeared on my 2005 Ford Fiesta, So i took into to my local garage. They couldn't diagnose the problem or tell me what it was. After researching on the net I come across the common problem with fuel injectors given the symptoms which are occurring.
After my own investigation I found what the problem is, it is my return fuel pipe from the 4th cylinder injector - Its completely snapped off the T piece like fuel line and p*ssing diesel on to the engine block, hence the tapping and the inch thick carbon layered up round the injectors.
Also, once I had taken my injector out this seal type thing was completely shafted. (picture attached) Is this a standard seal? as the ones ive found so far, look nothing like that.
What is the part called which goes into the injector which is snapped and where can i get a replacement? (Picture attached)
Uploaded with ImageShack.us
Thanks In advance
Thanks In advance
vdun01
Ford Fiesta
Oct 5, 2017 08:14 AM
Zoggon
Aug 10, 2015 10:39 AM
