frs mk1 bhp/torque compared to cosworth??
Old Oct 30, 2011 | 10:31 PM
col93saphcos's Avatar
col93saphcos
Default frs mk1 bhp/torque compared to cosworth??
what power would an frs mk1 need to be as quick/quicker than a 360bhp 4x4 saph cos?
have standard frs and trying to work whats needed for it to be as quick as my cossie,
its on 55lb siemens t34/48 32 psi boost,6 degree rear beam so handles good to,
cheeRs colin
Old Oct 30, 2011 | 10:47 PM
Rsmat's Avatar
Rsmat
My old 411bhp FRS when it ran around 290-300 it would keep with 330 converted saffs... So at a guess you would need around 330-350... There the same gearing iirc..
Old Oct 31, 2011 | 09:57 PM
col93saphcos
cheeRs,what like was 411bhp in frs?what turbo etc?
what power is possible from standard turbo?injectors?
what like are these johnfrs hybrid turbo?
cheeRs colin
Old Nov 1, 2011 | 12:45 PM
pee vee's Avatar
pee vee
You'll get around 310 out of the standard turbo if you are lucky and have a good exhaust and manifold.
Old Nov 1, 2011 | 12:47 PM
pee vee's Avatar
pee vee
Should Of said 310-320 . standard turbo is a gt25.. Does similar numbers to a t3 on a cossie.
Wilsfoci
15
Mar 30, 2016 10:26 PM
Oct 9, 2015 07:38 PM
Ben26
Sep 1, 2015 06:29 AM
Aug 14, 2015 07:29 AM
