3 door bodywork
Old Oct 30, 2011 | 01:04 PM
Harris.'s Avatar
Harris.
Default 3 door bodywork
Hi people, on the passenger side inner wing on my 3 door it has a patch of rust thats been there for around 6 years ,it had never got any worse so i just left it, its where the header thank scews in below the ignition amp. now the header tank has come unscrewd i want to get this repaired but cant stand filler etc so how much do you think i would be looking at spending?? i would take all the parts off ie tank,coil , (just so i know the bodyshop cant go for a little drive
Old Oct 31, 2011 | 10:37 AM
cossie891's Avatar
cossie891
I had my whole bay painted for Ł80 but I did all the prep work etc and supplied the paint
Old Oct 31, 2011 | 12:15 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
The rust can b worse than it looks mate,mine was Lol
Get some pics up for all to see on here
Old Oct 31, 2011 | 04:35 PM
Harris.'s Avatar
Harris.
Its the size of a 50 pence piece mate so no drama's lol i just want it sorted
Old Oct 31, 2011 | 07:39 PM
daz1968's Avatar
daz1968
It's double skinned round turrets and what is 50p sized could be a lot bigger when you have a proper look, a dremel is ideal with cutting discs to cut it out, then you can get a piece butt welded in. Mine had to have a small repair there but fortunately for me it was a very small piece. Investigate it yourself and cut out the rot at least then you know bodyshop won't cover anything up
Old Oct 31, 2011 | 07:59 PM
lacey's Avatar
lacey
Once it's cleaned up and weld ( if it's that bad under the skin) then get it leaded not filled if your a bit fussy
Old Nov 1, 2011 | 01:27 PM
Harris.'s Avatar
Harris.
Ive just been quoted Ł580 for both inner wings to be repaired and painted,along with the roof rails as the paint in them has also cracked This is to be leaded and not filled too
Old Nov 1, 2011 | 04:38 PM
R4N SS's Avatar
R4N SS
i stripped my 3dr as it had rust on the inner wings
Old Nov 1, 2011 | 05:41 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
Well mine had a bit of rust under the headet tank mount & 'little' bit elsewhere which can be seen on my thread showing the excellent work by special k
Just hope you don't have more like I did.....
Old Nov 1, 2011 | 07:35 PM
Harris.'s Avatar
Harris.
So do i mate but the car will be in good hands
Old Nov 5, 2011 | 06:37 PM
Harris.'s Avatar
Harris.
My car goes to the bodyshop tomorrow ,so ive started takeing bits out the engine bay,would it be ok to drive the car without the air box for about 1 mile?
chowfornow
14
Jan 5, 2019 09:01 PM
rsguy
44
Sep 29, 2015 03:29 PM
mpilk
Sep 27, 2015 09:21 AM
gcfcos
88
Sep 15, 2015 03:48 PM
