Converting Sapphire Recaros to tilt forward
Old Oct 30, 2011 | 12:30 PM
Iain Mac's Avatar
Iain Mac
Default Converting Sapphire Recaros to tilt forward
I recently read a post somewhere on here that said something like " it isn't hard to make them tilt".
Looking at a parts graphic, it does look as if the tilt mechanism is actually in the seats, but without a tilt lever or (presumably) the lift cables.
Has anyone successfully converted a 4-door Recaro to a tiltable version?
What parts are needed and where could I get them?
Old Oct 30, 2011 | 08:05 PM
cossiestu's Avatar
cossiestu
At a guess, as long as there is a mounting point to locate the lever its possible, or might be less messing about to just buy a pair of tilting seats and swap the Truman over?
Old Oct 30, 2011 | 08:10 PM
cossiestu's Avatar
cossiestu
Swap the trim, that should read!?
Old Oct 30, 2011 | 08:59 PM
DAN-Saff's Avatar
DAN-Saff
You could dismantle the cloth seats and swap the leather over and cut the hole in the side for the lift knob.
I've not done it myself but I have swapped covers between seats to make a mint set up so I'm pretty sure its possible.
Rsmat
89
Oct 12, 2015 07:50 AM
locum8
Oct 1, 2015 01:50 PM
Fil
Sep 30, 2015 12:08 PM
mondeomark
Sep 28, 2015 06:28 AM
