2wd saph offset
hi i have just got a set of 17s for my saph i was told they are off a cossy thay do fit but rub a bit the et is 18 , is it possible to get round this or are they completely wrong ? any one else run et 18 offset??
Depends what width the wheel is too.... makes all the difference. After all a 17x7 in the same offset as a 17x10 will sit entirely differently!
With rolled arches though Sierras can accept way wider wheels than most people fit. Look so much better than the usual 7J ET30ish stuff as well.
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
