3dr v 2wd handling
Old Oct 25, 2011 | 07:09 AM
lukeytheduke's Avatar
lukeytheduke
Default 3dr v 2wd handling
hi folks, it has been said that the 3dr feels realy loose round corners and handles bad, compared to a 2wd saph. Why is this as they basicly use the same parts.
Is just the fact the chasis is slightly older or another reason. Surely its more arodynamic and produces more downforce due to the big spoilers. I.ve only ever driven a 2wd and handling was great.
If someone could shed some light on the situation i would be very greatfull or maybe suggest the best way to improve a 3dr's handling. Cheers luke
Old Oct 25, 2011 | 08:02 AM
D16PJM's Avatar
D16PJM
if i remember correct i think there is 2 different anti roll bars for the 3 door as the early ones had the wheel slightly further back but was a bit twitchy so another roll bar was used that pushed the wheel forward slightly helping the handling, i think they are number'd to tell what one you have.
Iv never had issues with my handling but front and rear strut braces definately helped as did the coilovers so mine probably isn't a good comparison as not alot standard anymore.
Old Oct 25, 2011 | 08:37 AM
Char1ie's Avatar
Char1ie
Stiffer shell on the Sappire versus the 3 door.
Charlie
Old Oct 25, 2011 | 09:20 AM
lukeytheduke
What one have u got mate? Cheers for the pm btw.
Old Oct 25, 2011 | 09:41 AM
Phil2002's Avatar
Phil2002
Saff 2wd has a thicker anti roll bar 16mm where as the 3 door is only 12mm 4x4 saff and escos have even thicker anti roll bars.
Rear diff mount will most likely be shagged replace it with the MSD poly one fantastic upgrade for about 120 quid
Old Oct 25, 2011 | 09:45 AM
Phil2002's Avatar
Phil2002
you will need to changes the rear trailing arms to take the saff anti roll bar as they mount in different places.
Old Oct 25, 2011 | 10:02 AM
Mike1's Avatar
Mike1
Most road cars will no no longer be running exactly as per factory these days ( or will be on very tired OE springs/dampers/bushes and different tyres/wheels ) so it's a bit of a moot point nowadays.
The 3 door was developed to be a competition car - very fast responses almost to the point of being regarded as 'twitchy' for a road car. That was a common criticism of the 3-doors on the press launch and Ford reportedly made some changes to the power steering, front bush materials and settings etc to make them less 'nervous' for the average driver on heavily cambered/longitudinally ridged roads.
The later H14 ARB added about a degree of extra caster over the H13 arb as fitted to the very first 3-door cars. Some original customers had the H14 retro-fitted by the dealer under recall if they complained and I think the last of the 3-doors and the RS500s had the H14 type anyway as did the Sapphires. Think they were all 28 mm at the front on 2wders though.
When the Sapphire was released it had a 2mm thicker rear ARB ( 16mm over 14mm ). The shell was stiffer, spring rates went from 106lb/in to 118lb/in at the front and from 263 to 286lb/in at the rear. The damper rates were softer in bump but stiffer in rebound on the 4-door. Front camber was slightly more negative and the big change was the front steering knuckle where the roll centre was dropped from 144mm to 70mm above the floor.
All these changes helped rid the Sapphire of the corkscrewing motion that a standard 3-door can get in a long fast bend sometimes.
The sapphire was said to be a less 'nervous', more stable car when really pushed and this is oftten why they were timed very slightly faster round a track. On the flipside, keen drivers said the 4-door had lost some of the razor sharp turn in the 3-doors were sometimes criticized for.
Swings and roundabouts really but there's loads of bits you can get/do to make the cars handle 'better' for your use so I doubt there's much in it these days unless you wanted to compare stock factory cars ( and I doubt the OE tyres are still available anyway )
Old Oct 25, 2011 | 10:10 AM
Rsmat's Avatar
Rsmat
3dr's are mens cars... If you can drive one hard.
Old Oct 25, 2011 | 10:14 AM
dojj's Avatar
dojj
Resident Wrestling Legend
the simple fact of the matter is that the saph has a great big lump of metal along the rear parcel shelf sits whereas there is a big hole and a bit of cardboard on the 3 door
forget about the rest of the geometry and stuff as if the shell is going to flex then you are onto a looser from the off, and stiffening the suspension will just make matters worse*
*these onions are based purely on having owned both a 3 door and a saph and the saph was easily the better/nicer car to drive on a day to day basis
Old Oct 25, 2011 | 11:01 AM
dakar's Avatar
dakar
My saff is the worst handling car i have ever driven
Old Oct 25, 2011 | 11:04 AM
DAN P's Avatar
DAN P
does not matter to much they both dont handle very well standard
Old Oct 25, 2011 | 11:10 AM
daviddunlop83's Avatar
daviddunlop83
Old Oct 25, 2011 | 11:12 AM
Mike1's Avatar
Mike1
But well enough to beat the "best-handling M-car ever" with the same amount of power ( 200bhp ).
As Ford would say ....job done!
Old Oct 25, 2011 | 11:54 AM
plynchy's Avatar
plynchy
Nobody has mentioned centre of gravity?
Old Oct 25, 2011 | 12:00 PM
Twellsie's Avatar
Twellsie
i presume you are talking about the E30? if so there have been better handling M cars than that....
Old Oct 25, 2011 | 12:01 PM
Twellsie's Avatar
Twellsie
i would suggest its because it bears no relevance, anything of any significant weight is all in the same place
Old Oct 25, 2011 | 03:02 PM
Mike1's Avatar
Mike1
Reason I put it in quotes, was that it was a monthly car mag's opinion, not mine. Nevertheless, still rated quite highly although 'handling' will always be a subjective issue
Old Oct 25, 2011 | 03:31 PM
james kiely's Avatar
james kiely
good info mike
Old Oct 25, 2011 | 05:50 PM
Mike1's Avatar
Mike1
good info mike
As dojj says, one of the big differences is the big hole in the back of the 3-door
Old Oct 25, 2011 | 05:52 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
I take it you drove 2 standard cars to make the comparisson?
Old Oct 25, 2011 | 06:49 PM
Smiler's Avatar
Smiler
Would a rear strut brace be enough to bring the 3-door shell up to the saphires standards as far as rigidity is concerned?
Bit of an off-shoot, but how would an XR4i shell with it's extra rear pillars compare to the Cosworth 3-door shell?
Old Oct 25, 2011 | 07:26 PM
dojj's Avatar
dojj
a strut brace only ties the strut tops together, but if these can flex then it's not doing uch in any case
the saph shell has the 2 sides stuck together with the rear screen, roof, parcel shelf and even the opening in the rear seats is smaller, plus it's got a much bigger bit of metal along the rear of the doors to help tie everything together
you would need to basicly weld in a saph rear end to the internals of the 3 door to get the same sort of rigidity, don't forget that the boot lid isn't structural on the 3 door either
the 4i shell is the same bar the extra bits of glass and strips, and they aren't really structural either as they don't tie anything together
Old Oct 25, 2011 | 08:57 PM
Smiler's Avatar
Smiler
I see what you mean.
Old Oct 25, 2011 | 09:17 PM
Staffi's Avatar
Staffi
Not many Rich, i've owned E30 M3s and the chassis are brilliant had my E36, that felt lardy as fook, E46 i never drove it in anger as it was a mates car so couldn't tell, but E30 M3s handle superbly well, better than any 3dr or saff...
Old Oct 25, 2011 | 09:50 PM
martysmartie's Avatar
martysmartie
But still coulden't beat the Ford round a track
Martin
Old Oct 25, 2011 | 09:55 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
Biggest problem is old tired bushes and dampers, and the rear beam geometry. If you don't sort the rear beam it will never be good.
Old Oct 25, 2011 | 10:19 PM
BRAMMER's Avatar
BRAMMER
Mines got adjustable arms etc, coil overs, struts F+R, wide wheels and good road tyres and i can put the power down well with very little trouble - mine kicks out hard in 3rd on full boost thats about as twitchy as it gets - that was at 35psi
Looking forward to getting a rear beam in the future to actually see what difference they make to a road car.
Struts are an absolutely must on the rear of 3dr's for obvious reasons
Old Oct 26, 2011 | 07:48 AM
Mike1's Avatar
Mike1
Agree with Wil - surprising how much 'steer' effect on the front end the standard beam provides even if in good nick.
To be honest, even an E36/E46 BM with a more sophisticated rear suspension set-up will feel all over the place once the RTABs have worn and the back will 'steer' the front end over cambers/longitudinal ridges etc
Old Oct 26, 2011 | 08:48 AM
cossie891's Avatar
cossie891
what about if you fitted a strut brace that bolts to the floor on the 3 door will that stiffen it up good enough?
Old Oct 26, 2011 | 09:38 AM
dojj's Avatar
dojj
that would triangulate the strut tops, but the shell flex would still be there
the next time you are out and about in your car, lower the window and put your hand on the gap between the door and the roof and, as you drive along, just feel how much flex there is
you may be surprised
Old Oct 26, 2011 | 07:23 PM
Sonic Boom's Avatar
Sonic Boom
Yep it will pinch your fingers
Rich
Old Oct 27, 2011 | 01:47 PM
Mike1's Avatar
Mike1
Adrenaline do frame connectors as well which some people recommend
http://adrenaline-race.co.uk/#/products/4531949876
wowk
Mar 30, 2021 07:49 PM
martynhomer01
Oct 1, 2015 12:05 AM
mark r
Sep 29, 2015 07:27 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
